how to get rid of the tire mobility kit warning lite?
Discussion in 'Mustang S550 General Forums' started by inspecto, May 29, 2020.
  1. inspecto
    inspecto Member
    First Name:
    mike
    Vehicle(s):
    2017 Mustang GT
    Mar 2, 2019
    as the title says . Every time I start the car my center stack message is to ck the T. M .K.
    I replaced the kit with real spare when I bought the stang. just started recently to do this.
  2. Monopoly
    Monopoly Well-Known Member
    Vehicle(s):
    2017 Mustang GT, 2012 Civic Si
    Jul 29, 2016
    Toronto
    787
    215
    0   0   0
    its in the vehicle settings.
  3. Spartan1
    Spartan1 Active Member
    Vehicle(s):
    2019 GT
    Apr 6, 2020
    SE MI
    74
    0   0   0
    Happened on my daughters 2012 C-Max my mom gave her after getting a new car. It's on the cluster, it's timing related for every 2 years, you can choose when to have it go off again in 4 years, was pretty straightforward, give it a Google.
    Edit - or watch that video
  4. Ronin47
    Ronin47 Well-Known Member
    Vehicle(s):
    2019 DHG BULLITT K4675
    Apr 20, 2019
    Canada
    144
    75
    0   0   0
    You can disable it in FORScan here:
    720-03-02 Cxxx xxxx - Tire Mobility Kit disabled in IPC
    720-03-02 Dxxx xxxx - Tire Mobility Kit enabled in IPC
  5. Elp_jc
    Elp_jc Well-Known Member
    First Name:
    JC
    Vehicle(s):
    2019 Bullitt K7979, MR, Nav, B&O, Cover
    May 2, 2020
    El Paso, TX
    1,012
    161
    0   0   0
    Great info; thanks. Hey, do you know if in that same ID, changing the xxx8 to a xxx0 disables the IPC welcome (blue) screen? It's supposed to, but not sure it did. It's based on the F-150, but it's probably wrong, since the first digit does NOT have the info about the tire mobility kit you posted. I'd also like to eliminate the Ford animation for a 'quick boot', but the F-150 instruction doesn't work either. If you know how to accomplish those 2 tasks, I'd greatly appreciate the info :D. Thanks man.
  6. Sixxarp
    Sixxarp Member
    First Name:
    Vehicle(s):
    2019 Mustang Bullitt, 1968 Chevy Camaro
    Sep 2, 2019
    Pleasant Hill, CA
    You could just keep it as a reminder to check the tire pressure in your spare. I have heard stories of spares loosing a lot of air pressure over time. I'm leaving mine on for that reason.
Loading...
Share This Page
