RichGT350R
Looks like you found your answer. Sorry for the confusion! Best Regards!
720 degrees divided by 8 cylinders is 90 degrees. BTW, the cylinder banks are at 90 degrees to each other across the valley.Messing
Perfect explanation. Thanks720 degrees divided by 8 cylinders is 90 degrees. BTW, the cylinder banks are at 90 degrees to each other across the valley.
So when the FPC is "up and down" to the left bank, two pistons are at TDC and two at BDC. Of the two at TDC, one is on a compression stroke and is ready to fire, while the other is at the top of the exhaust stroke. Meanwhile, all the right bank pistons are half-way between TDC and BDC and moving fast. At this TDC moment, the ready-to-fire left-bank cylinder fires.
90 degrees later, the left bank pistons are all half way and moving fast, while two right bank pistons are at TDC, one ready to fire and one at the top of the exhaust stroke. The other two right bank pistons are at BDC. Then the ready to fire cylinder fires exactly 90 degrees after the previous left bank firing described above.
This process repeats every 90 degrees of rotation, and after happening 8 times, all 8 cylinders have fired once and the engine has turned over exactly two revolutions.
In a CPC engine, the same thing happens, but the timing is different because the crank throws are offset 90 degrees instead of 180 degrees. At any TDC moment, two pistons are at TDC, two are at BDC and four are half-way, just like the FPC, except that the CPC makes sure the two at TDC are on different banks where the FPC makes sure they're always on the same bank.
This difference is why the CPC engine runs smoother than a FPC engine. Every 90 degrees, the FPC engine has, on one bank, two pistons stopped at TDC and two stopped at BDC, while on the other bank it has four pistons that are half-way and moving fast. In contrast, every 90 degrees each bank of the CPC engine has one piston stopped at TDC, one stopped at BDC and two moving fast at half-way. It's got a better balance of motions, so it runs smoother, but it has the downside of having two cylinders fire on the same side once every revolution. You trade off highly balanced air movement (ie-power) for highly balanced mechanical movement (ie-comfort).
As was II think the OP was thinking 180 deg / FPC was like a boxer engine.
