How can I determine if 19' GT has MagRide
stang-man
Tampa, Fl.
17 Lightning Blue GTPP
I am remotely looking at a Supercharged 19' GT.
Can I tell from the dash or from a setting if the car has magride?
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Yes, on the digital dash there's a screen where you configure MyMode, and all the current settings are displayed at once. If you see a setting for the suspension (the icon looks like a damper), then it has Magneride. If you don't, then it doesn't.
Or, if you have the VIN, you can look it up in Etis. If you don't have an Etis account, send me a private message with the VIN and I will check it for you.
Joker721
Henderson, NV
Jim
01 Bullitt DHG, 2020 Camry WCP TRD
There should be little black caps (looks like tire caps) on top the top of the camber plates for the Magnaride
13GetThere
Kentucky
Lynn
For the 19 MY, I believe only the Performance Package Mustangs came with Magnaride. Optional in PP1, standard in PP2 , GT350 and R.
EFI
Masshole central
5.Br0
Look to see if you can change suspension settings in the dash, or use a VIN decoder to see if yours came with that option, or look for a wire coming out of the bottom of your struts/shocks.
kz
West Chester, OH
Mustangs & F150
If the car has a regular dash (not the digital one) you cannot tell in any way from the settings whether it has Magride.
If it doesn't have a Peformance Pack, it for sure does not have it.
The only sure way to tell then is to look at the dampers (wiring coming out) and verify presence of VDM (vehicle dynamics module) on the right side of the trunk under the carpet. Alternatively, look for ride height sensors on front and rear control arms but that requires deeper look into suspension parts.
