How bad are the stock 235 Pirellis for a road trip?
LeroyJohsan
Chicago
Leroy
Mustang GT
Going to be taking a road trip later this year of about 2000 miles. Lots of warm open straight roads.
I’ve seen lots of posts about how bad the stock Pirellis are on the GT.
how bad are they really and will it ruin my drive?
Do I need a better tire or a wider tire?
sjmurphy34
Michigan
17 GT PP Magnetic
For normal driving they should do perfectly fine and probably net you better fuel economy since you have less friction than a wider tire. Where they typically suffer is any type of performance driving or if you have a bit of a heavy foot and try to accelerate from a stop too hard.
LeroyJohsan
Chicago
Leroy
Mustang GT
So no issues with rolling starts like if I want to do a 40-80 pull on the freeway?
sjmurphy34
Michigan
17 GT PP Magnetic
Well I don't think I would say no issues but less so than from a stop I'd think. Any time you go WOP with those tires, assuming you're not in a high gear, you'll probably have some traction issues. Sorry I must have misunderstood your initial question. I thought you were more so just referring to normal cruising.
LeroyJohsan
Chicago
Leroy
Mustang GT
I mean I’ll be driving normally for a majority, but I do like some light pulls.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Cross country the 235 is probably the best choice. A narrower tire will deal with bad weather better than a wide one. You will be able to play a bit but will not hook as good as a wider tire. If you have throttle, steering and brake control you can do some pretty spirited twisties also.
There are several very vocal people on this board who think if you have a mustang gt you need 11" wide tires, full coil overs and shift at 8000 RPM. If you don't you need to buy a diesel.
Ignore these people
accel
'17 GT PP
Warm weather I'd say no issues.
I autoXd and car control clinic'd on stock Pirellis with no issues. It's when it is cold and wet when I have to be cautious.
zEven then once you warm them up they get better.
MRGTX
CT
2020 Mustang GT 6spd base
Try to keep this in perspective. These no-season 235 section Pirellis are still a superior performance tire to any DOT legal tire you could buy through the 1980s and maybe beyond that. Even “bad tires” are pretty good these days.
They’re FINE.
No, you will not be able to experience the limits of the Mustang’s performance potential and they won’t save someone from driving like a baboon like many real performance tires but they’re reasonably grippy, relatively long wearing, relatively low rolling resistance, safe tires.
