honeybadger
Just don't care
Love the technical answers! Thanks for chiming in and helping educateEchoing HB a bit, but ...
Not exactly the same thing.
Overall - if you maintain the tire in a healthy part of the camber curve and reduce the time the suspension takes to settle when you change direction (steering input), your turn-in response will increase. This is largely a function of spring rate, with contributions from springs and roll bars. But tire sidewall height, alignment, and aero matter too.
Once into the corner and the car is "set," max grip can be higher with softer settings, to a point. It's like you want the softest setting that is stiff enough to maintain camber and use both inside and outside tires.
Because of the inherent weakness of a Macpherson strut, specifically that camber curve goes into positive after a certain level of suspension compression - it is usually a matter of compromising on the "too stiff" side. Too soft can hurt both turn-in and mid-corner grip by giving up negative camber (tire camber goes positive under constant lateral load). Too stiff and you "skate" because you don't transfer enough weight to fully maximize the tire grip - which usually shows up as corner entry and mid-corner understeer. But too-stiff gives better transitions and better braking, relative to too soft.
In the wet, it all changes again ...
