Help my 2019 Mustang Ecoboost is stuck in Park!
jholly36
Illinois
2019 Mustang
Has anyone been permanently stuck in park? Any ideas why I am stuck in park? It is an automatic
lacanteen
Louisiana: Cajun Country
George
Does the shifter move? Is the car parked on an incline?
jholly36
jholly36
Illinois
2019 Mustang
Shifter does not move. Nope car not on incline. Had two guys shimmy it also while I turned the wheel, still stuck.
jholly36
jholly36
Illinois
2019 Mustang
I had it remote started, hubby entered the car with the fob, got something out and I relocked the vehicle. Problem started after that. Do you think we confused the system?
DropTopBob
Manassas, VA
Bob
2017 EB Conv, Perf Pak, Borla Sport Axleback
Yep, when you remote start you need to push the Engine Start button in order to shift out of PARK.
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
If locking/unlocking with the same FOB doesn't do it...try waiting the 40 minutes and see if everything resets to normal. This is what happens when you leave an interior light on...wait 40 minutes.
Best of luck.
CVCAshnere
jholly36
jholly36
Illinois
2019 Mustang
Yes after we hit the Engine Start it still does not shift. Went back after an hour with another fob and still no go. That time not remote started. Did try several times also after remote starting and turning off - no luck
jholly36
jholly36
Illinois
2019 Mustang
Best of luck.
CVCAshnere
Thanks, I know we went back an hour later with a different fob but not sure if we took the first fob through the sequence again. We’ll go back and try with the first fob it has definitely been forty minutes
familyman
Bunker 103
2019 GT PP1 Ruby Red
Is the steering wheel turned all the way in either direction?
Bran2TheDon
SouthWest Virginia
Brandon
2015 Comp. Orange GT
Brake pedal switch gone bad.
Are your taillights coming on when you press the brake?
