Help. 2015 Mustang USA to EU specs
Discussion in 'Europe' started by osvega2020, Jan 3, 2020.
  1. OP
    osvega2020
    osvega2020 Member
    First Name:
    os
    Vehicle(s):
    Mustang Fastback 3.7
    Dec 29, 2019
    Spain
    Hi Ericc, i saw in many youtube videos how VLAND lights are intalled in american cars and they work with all 5 modes as an EU car, I post the link because maybe Im wrong:
    About fog light with OEM switch is here made by @Falk03: https://mustang6.de/viewtopic.php?f=16&t=7151#p176474
    thanks
  2. Ericc B
    Ericc B Well-Known Member
    Vehicle(s):
    2016 GT Fastback
    Oct 30, 2013
    Netherlands
    3,281
    1,174
    0   0   0
    Hi,
    That's an amazing project car and I'm quite surprised he got it to work :)
    I tried to make a compact translation for you, here it is:
    1. Replace the original switch with one that includes a switch for the rear fog lamp. You can buy this at any Ford dealer but they German guy found one on eBay from a Ford Mondeo MK5. Part number is DG9T-13D061-FCW and it is identical to the version for the Mustang except for the part number.
    2. Both the new light switch and the Body Control Module need additional plugs. On the light switch C205 # 2 and on the Body Control Module C2280B # 8 and C2280C # 25. You can buy these at mouser.com. The cables need to be modified (wrong diameter). Here are Mouser's part numbers:
    C205: 26 AWG 2098762-3 or 7
    C2280B: 26 AWG: 571-1924955-5 or 7
    C2280C: 18-20 AWG: 33012-3022 or 33012-2022
    Since Mouser is designed for larger order quantities, ordering 10 terminals each was relatively expensive.
    3. The wiring connections:
    * C205 # 2 to C2280B # 8
    * C2280C # 25 to the rear fog lamp
    5. Forscan programming of the Body Control Module:
    726-28-01 xxxx x*xx xxxx Rear Fog Enable Cfg: 0=disabled --> 1=enabled
    726-24-01 xxxx xxxx *xxx Interior Lighting (IL) / White Lighting (WL) / Backlighting LED (BL) / Rear Fog Lamp (RFL) - Circuit DTC (Normal/Inhibited): 5=IL norm, WL inhib, BL norm, RFL inhib --> 4=IL norm, WL inhib, BL norm, RFL norm
    6. Forscan programming of the IPC (instrument panel cluster) so that the indicator light is also displayed:
    720-02-02 xxx * xx Rear Fog Indicator Cfg: 0 = disabled -> 2 = enabled
  3. OP
    osvega2020
    osvega2020 Member
    First Name:
    os
    Vehicle(s):
    Dec 29, 2019
    Spain
    Many thanks for traslation but the problem for me is that I dont know how to find the c205 switch, de c2280b module, etc. also the next references of section 2. sorry :(
  4. Ericc B
    Vehicle(s):
    2016 GT Fastback
    Oct 30, 2013
    Netherlands
    3,281
    1,174
    0   0   0
    The body control module is a plastic box with fuses, connectors and electronics in it. The way I understand the German guy's description is that of the 3 new connectors you have to buy 1 goes on the back of the new light switch and two go into the BCM. The car has 2 BCM's, the main one is located behind the passenger lower cowl trim panel, and BCM-B is located in the trunk on the passenger side behind the side trim panel. s-l1600.jpg
  5. Falk03
    Falk03 Well-Known Member
    First Name:
    Falk
    Vehicle(s):
    Mustang Convertible
    Aug 9, 2017
    Munich, Germany
    176
    66
    Rating:
    100%
    1   0   0
    The connector C205 is the one at the back of the light switch. All the C2280? connectors are the ones going into the BCM. Have a look at the attachment for the different connectors.
    Ericc B likes this.
  6. OP
    osvega2020
    osvega2020 Member
    First Name:
    os
    Vehicle(s):
    Dec 29, 2019
    Spain
    Thank you so much, I will check when car arrives And I will tell you!
  7. vincentjm
    vincentjm Well-Known Member
    First Name:
    Vincent
    Vehicle(s):
    '15 Mustang GT PP
    Mar 23, 2019
    Switzerland
    77
    Occupation:
    System Engineer
    0   0   0
    Offtopic, but here in Switzerland we allow the OEM red sequential turn signals, I always get weird looks when I turn them on somewhere in in Europe. Been stopped by the cops a few times now because of the turn signals and the front amber marker lights :giggle:
  8. MustangGT5.0
    MustangGT5.0 Member
    First Name:
    Tim
    Vehicle(s):
    Ford Mustang GT, BMW M4, Volvo XC90, Ford Taunus 2.0GL
    Apr 30, 2020
    40
    Garage Profiles:
    Hi, does anyone have similar pictures as below including the Pin numbers for connectors C2280B and for C205 ? I'm working on the fog light mod for my 2017 Mustang. Thanks!
  9. Falk03
    First Name:
    Falk
    Vehicle(s):
    Mustang Convertible
    Aug 9, 2017
    Munich, Germany
    176
    66
    Rating:
    100%
    1   0   0
    Here you are...
    ps: This is for MY16 but I guess MY17 is the same (maybe the coloring are different).
  10. MustangGT5.0
    MustangGT5.0 Member
    First Name:
    Tim
    Vehicle(s):
    Apr 30, 2020
    40
    Garage Profiles:
    Fantastic. Thanks so much!
Loading...
Share This Page
