Has anyone installed the ZL1 tow hook without removing the front fascia?
Discussion in 'Shelby GT350 Mustang' started by matthewr87, Feb 6, 2020.
  1. matthewr87
    matthewr87 Well-Known Member
    Vehicle(s):
    2018 GT350
    Oct 13, 2013
    94
    55
    0   0   0
    I need a tow hook for the track. However, I have little appetite for removing the front fascia (based on previous negative experience with another Mustang). ZL1 addons says it is possible to install just by removing the front belly pan. Is this true?
    Does belly pan removal necessitate removing the front splitter?
    Also, can it be mounted on the passenger rather than driver side?
  2. svassh
    svassh Well-Known Member
    First Name:
    Scott
    Vehicle(s):
    2019 Shelby GT350R Performance Blue Metallic
    Aug 14, 2019
    Highland Village, TX
    307
    236
    0   0   0
    "ZL1 addons says it is possible to install just by removing the front belly pan. Is this true?"
    Interesting, I've been facing the same decision. I dread taking off that whole front fascia. Hope you get some good responses.
  3. Bullitt40
    Bullitt40 Well-Known Member
    First Name:
    Vehicle(s):
    2016 GT350/track pak
    Nov 27, 2017
    Fl
    57
    33
    0   0   0
    Yes, I installed mine without removing front fascia. It was tough, but possible. Took a couple of hours and my main problem was a ground strap that I could not see. Once I unhooked the strap it went on fairly easy. tow hook (2).png
    overdrive714 likes this.
  4. Tomster
    Tomster Beware of idiots
    First Name:
    Tom
    Vehicle(s):
    2 - '17 and 1 - '18 GT350 R's
    Feb 20, 2016
    7,515
    6,227
    0   0   0
    I've done it both ways. Either way will take time. Removing the front fascia is the easier way to go IMHO.
  5. OP
    matthewr87
    Vehicle(s):
    2018 GT350
    Oct 13, 2013
    94
    55
    0   0   0
    Okay thanks guys. Did you have to remove the front splitter to remove the belly pan?
  6. Bullitt40
    First Name:
    Vehicle(s):
    Nov 27, 2017
    Fl
    57
    33
    0   0   0
    Yes
  7. oldbmwfan
    oldbmwfan Well-Known Member
    Vehicle(s):
    2017 GT350R
    Oct 19, 2016
    Chicagoland
    504
    466
    0   0   0
    Yes, and yes the splitter comes off. I'm glad I did it that way because I found the dealer had left a bunch of the proper hardware out of the splitter install, and I had to order it and add it back in. Lazy jerks.
    Coyote Red likes this.
  8. jashton
    jashton Well-Known Member
    Vehicle(s):
    Mustang
    Mar 4, 2016
    111
    33
    0   0   0
    The bumper comes off easily, no reason to make things more difficult. The only thing you need to be careful with is the tabs on the sides when popping them off.
  9. The Chairman
    The Chairman Well-Known Member
    Vehicle(s):
    ‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500
    Mar 18, 2016
    South TX
    574
    349
    0   0   0
    I think the ZL-1 Tow Hook only mounts to the passenger side (that’s where I mounted mine). Not sure it can be mounted on the driver’s side based upon how its made. Maybe its been done?
  10. drummerboy
    drummerboy Well-Known Member
    Vehicle(s):
    '19 GT350
    Mar 15, 2019
    SoCal
    131
    58
    0   0   0
    Just FYI, the ZL1 addons tow hook also has a center mount option if you like drilling.
  11. REDLINE
    REDLINE Well-Known Member
    Vehicle(s):
    2017 Z51 Stingray
    Apr 16, 2018
    Los Angeles
    152
    35
    0   0   0
    Is it true that you DON'T have to remove the splitter from the bumper if you remove the whole bumper?
  12. 16 Magnetic
    16 Magnetic Well-Known Member
    First Name:
    David
    Vehicle(s):
    2016 Shelby GT 350
    Oct 5, 2018
    Ohio
    233
    183
    0   0   0
    he left his on when he took the whole bumper off. I’ve seen other videos where the splitter is left on as well.
  13. Tomster
    First Name:
    Tom
    Vehicle(s):
    Feb 20, 2016
    7,515
    6,227
    0   0   0
    It all comes off pretty easy. It looks worse than it is.
    It's just time....
  14. Alain
    Alain Well-Known Member
    First Name:
    Alain
    Vehicle(s):
    2016 Challenger Hellcat B5 Blue/ 2018 ZL1 1LE Pull Me Over Red/ 2019 350R Oxford White, Black Stripes, CF Dash, Tech Package #413
    Jan 24, 2018
    Northern NJ
    495
    190
    0   0   0
    I am facing the same exact dilemma !!!!
    i'm dreading having to take off the front of the car. I still haven't installed my front splitter so I might look into that avenue before I install the splitter.
  15. Tomster
    First Name:
    Tom
    Vehicle(s):
    Feb 20, 2016
    7,515
    6,227
    0   0   0
    Yes, without a doubt, do it before you install the splitter.
    Take your time, it goes easier with the fascia off. I've done it both ways.
    Alain likes this.
Loading...
Share This Page
