xraystyle
- Oct 25, 2016
- Los Angeles
- 2016 Ecoboost Premium, Magnetic
Bump -
How’s it going for the DSR1 users - easy to work with for upgrading behind stock and using Line Out converters?
I'm not sure you'd need a DSR1 if you're using LOCs. This is assuming you have the non-premium factory sound system. The non-premium system doesn't have a separate amplifier under the kick-panel, so if you're just tapping into the speaker wire with LOCs, running to your own amp, then out to the speakers again you wouldn't need any additional modifications to keep all the controls and whatnot.
The DSR1 comes in when you pull out the factory amp from the premium sound system. The wire harnesses connect directly to the head unit (which puts out line level), then the DSR1 emulates the factory amp as far as the car is concerned while giving you all the RCA outs and signal processing and whatnot.
