Captian_Eddie
Does anybody have a good source for vinyl letters for the GT500 on the bumper and the Shelby on the front?
TIA
Ed
TIA
Ed
https://www.bemarofilms.com/onlinestoreDoes anybody have a good source for vinyl letters for the GT500 on the bumper and the Shelby on the front?
TIA
Ed
KB in the future I would clean and then Alcohol the inserts before all it in, or it could be the textured (Dont have one so guessing still) surface could be the other issue which at that point silcone cant work, or permanent gorilla glue if you dont have plans to remove them.Curtis: I don't think DomedLetters makes the "GT 500" for the bumper guard but hope you find another source.
For anyone else, I'll repeat what I found out about the domed versions...a bit higher than average speeds on a social distancing drive caused half of them to fly off.
Mark B. used a tube of 100 percent, clear silicone to attach his and they stick well with that method.
In DL's defense, he is sending me another set and I plan to pick up a toob of dat stuff. :-)
Seriously Pressure washer? Let me pressure wash your skin and tell me how long your skin will stay onThe splitter is textured plastic and the vinyl and domed letters would not stick after a few passes with my pressure washer. I figured the only solution was to glue them down. I did not want to use a permeant glue like gorilla glue or epoxy in case I wanted to change out the letters for a different color. Ended up using regular silicone glue. Just applied a very thin layer on the back side of each letter and so far, they are holding up well. Not sure how long they will last on there but I have no problem hitting them with my pressure washer although I don't get right on top of them.
Mark, what I am wondering is if you are saying the letters on the splitter itself are textured, and not smooth? My splitter is textured, but each of the letters indented into it are smooth, not textured.Jaime, I meant the splitter is textured plastic and the adhesive on the domed letters (they are smooth) I got would not stick well to it. I bet the adhesive on the letters you got from Zimcraft is much better if they stick well.
