PUR_SPD
As soon as I get them mounted and on the car I'll update with photos. Hopefully later this week. Tires are arriving tomorrow.
Sounds good. I have a rapid red / black OTT stripes 500 on order so will be paying close attention to what they look like on your car.As soon as I get them mounted and on the car I'll update with photos. Hopefully later this week. Tires are arriving tomorrow.
Yes they are made to take OEM Lug nuts, OEM Center Caps, OEM Tires and OEM TPMS Sensors.Would it be too much to ask what your finished lug hole diameter is? I ask because you mentioned in the initial post about these being "a direct bolt on with all factory specs" and you also stated that you'd be able to use the factory lug nuts. I measured my own factory OEM GT500 (Base) wheels and the diameter of the lug holes was consistently ~17.34mm to 17.35mm.
You have the OEM Tob, are you still looking for aftermarket wheel sizes?You can vary the lug hole diameter to a point and still use the OEM nuts. I'm asking for the lug hole diameter because I find the wheel compelling and that dimension is important for other reasons...
They absolutely should have the dimension. By all means, measure yours when you get them if you can.LAM should have those specs from their CAD work. Otherwise I'll be happy to play engineer and measure with my caliper.
Pics will come from Austin in a week or so. Too cold here to swap wheels, it can wait until I get to Texas.
OEM doesn't mean much but quoting the actual dimension is important and I think you just might know what I'm getting at. I like that wheel they are doing but clearances between the stud and the corresponding wheel hole diameters are kind of important for reasons I can't get into yet. Just looking for the number they are using...You have the OEM Tob, are you still looking for aftermarket wheel sizes?
We are not cutting the wheels to look like the Carbon Wheels, similar design but the not same.They absolutely should have the dimension. By all means, measure yours when you get them if you can.
Sadly no they cannot be made in 19" the brakes are too massive for us to get proper forgings to clear.Great looking wheel! Who makes these? Hope they come in 19’s
I was thinking 19’s for the 350’s and GT. Not just the 500. What company makes these? I looked at your website and couldn’t find them.Sadly no they cannot be made in 19" the brakes are too massive for us to get proper forgings to clear.
