GT350R Wing install
BaseEcoboost
California
Base 2015 Ecoboost
I have purchased a used exposed Carbon fiber GT350R wing made by Carbon Dynamics; I have the holes and everything drilled out and was wondering if anyone had any tips for the actual install of the wing should i just use alot of 3m tape and the bolts or should I use 3m and a felt around the outside like the Anderson composite wing install? Looks like it will have some gap and the more "padding" I add the better the fitment would be.
17again
Dallas, TX
Vince
2017 Mustang GT Grabber Blue
I installed the OEM GT350R wing on my GT and the install was pretty easy. I used the 3M tape that came on the wing and as I was pushing the studs through the holes I made sure the wing as lined up as I pressed it lightly down. Then I went and installed the nuts and like a tire, I went back and forth on the nuts lightly tightening them down.
Don't overthink it, simple process that will make your S550 look great.
