As I sit here typing at 0137 hours I think it might be killing me lol.My dude you are killin' it!
Sure doesn't sound like it. I would touch base with ARPI sent Permatex an email about torque specs with their anti-seize, and then found this digging around in the FAQ...
Permatex® does not recommend the use of any anti-seize product on wheel studs. Many people have used anti-seize for this applications, however, there is the potential for over-torqueing and therefore, higher clamp loads and potentially dangerous bolt stretch. Because of the lubricity of anti-seize, there is a tendency to over-tighten because of the ease with which the nut will bear down on the lug. For this reason, even if you try to torque the nuts to factory specs, the clamp load may become too high depending on the type of bolt, size and manufacturer.
Guessing they're not going to make a recommendation when they write back :-/
What did you do with yours? Anti seize on there? What torque?Sure doesn't sound like it. I would touch base with ARP
I am using ARP. Torque to 130 ft/lbs, drive, and re-torque to 140 ft/lbsWhat did you do with yours? Anti seize on there? What torque?
You mean the ARP Ultra Torque Assemly Lube? You have ARP studs or stock studs? APR give you those specs or did they give you some math (like reduce 10% or something?)?I am using ARP. Torque to 130 ft/lbs, drive, and re-torque to 140 ft/lbs
Stock studs with the Assembly lube.You mean the ARP Ultra Torque Assemly Lube? You have ARP studs or stock studs? APR give you those specs or did they give you some math (like reduce 10% or something?)?
