That's actually not true. My fully loaded Gt PP premium with Recaros weighed 3748 bone stock with only a quarter tank of gas. The recaros save about twenty pounds over the heated and cooled power seats, and add at least another 65 pounds for the 3/4 tank of gas. That brings a fully loaded Gt without recaros, and a full tank to about 3,833 lbs.
a fully loaded Gt vert is probably pushing 4,000 lbs.
No, they do not, I'm not sure where you got this information, but its incorrectb/c BMW USA weight includes driver, simple as that
DIN weight (used in Europe) is without driver, 90% fuel and fluid
According to Ford the tech pack is only 9 pounds heavier than the track pack.Gt350 Recaros are lighter than the GT Recaros. Those tech seats are easily over 20lbs heavier than the recaros each. Add the "junk" in the trunk that was taken out and sync and it's going to be over 3,833.
I was just comparing coupes, convertibles would be heavier for sure.
First off, M4 makes more than the rated power in normal use. Second, it has more area under the curve than a non-turbo motor. AKA see why a 300hp EVO is faster in a straight line than you would expect comparing it to say a 300hp non-turbo V6 car of the same wieght. Last gearing matters. The GT350 has about as perfectly wrong gearing for a dragstrip as you can get without going full early USDM early STi retarded. GT350 would be faster with 3.11's or 4.10's (or deeper). Right now it gets an extra shift in to every magazine metric without using that gear long enough to cover up the time lost shifting. 3.11's would be fun to launch correctly, but would remove a shift out of the 0-60 and 1/4 mile. 4.10 gears would let you finish the 1/4 near the top of 4th which would now be good to 127mph with GT350R diameter tires.that's the thing, bmwusa.com uses EU weight + 10% more fluid, plus whatever options that have more than 33% take rate.
the Eu weight includes 75kg driver, where as Ford listed the weight without driver.
anyways, now I kinda understand why, after the 1/4mile time got published, people on this forum went nuts claiming it was too slow. no wonder the gt350 (which I have) manual vs. manual can't pull away from m4 in the 1/4. with 100hp more power but at least 400lb+ diff. that's why.
US curb weights are defined by the certain government entities, not BMW. All published US curbweights are WITHOUT driver, 100% fluids, and some options depending on how the car is sold.
Don't forget the track pack has two extra coolers, and two pumps for those coolers, and a bigger spoiler.
DIN WEIGHTS DO NO MATTER IN THE USA. How many times do I have to repeat it? Please forget about wat a DIN/EU car weights, period. Different standard, different car entirely due to emissions and US safety regulations
How are you going to ignore all of the posts that clearly show what it really weights, you know, a US car, on scales? Its not a 3300lb car, not anywhere near it, at least not int he US.
Please read the section on how US curb weight is defined. If BMW wants to sell cars in the USA, they have to list the cars weight as it would sit on the curb, here in the USA. Pretty simple concept really. No driver, full fluids.
http://f80.bimmerpost.com/forums/showpost.php?p=15066497&postcount=49
THISLook at the photo of the car on the scale, man. What more proof do you need?
