Bob Loblah
When changing transmission fluid, are there any additional actions required to drain the fluid in the cooler and cooler lines or does all the fluid drain to the pan? Thanks.
That's a great document. Do you have one for the rear differential?like I said, drain, fill, and idle.
The service manuals are not expansive, if you own this car you should have it.
View attachment Transmission drain and fill.pdf
Thanks for providing a source! Good info for those of us looking for a service manual@AdamIsAdam : RE: what Tomster said, you can buy the OEM manual for relatively cheap.
Factory Manuals (factory-manuals.com)
I use these guys and buy the "deluxe" version since it includes working links - at least for the Ford manuals......for some reason the links don't work in the Subaru manuals....
Give them your VIN, ~ $140, and a couple days later you'll have the 10,000 pg + OEM service manual in *.pdf form.
Apologies if external links aren't allowed
Hmmm....their writeup makes it sound like all versions are "deluxe" now. Nice to save $40.When I went to 2017, I don't see a deluxe version option and it was only $100.
