GT350 racing thermostat question
Inthehighdesert
NM
Charlie
It was sarcasm. I’m very aware how a cooling system works.
When an engine is cold it needs a much richer (more fuel) mixture to burn resulting in a dirtier and inefficient burn. So a modern car tries to get the engine up to operating temp as quickly as possible. So when the engine is cold and you start it, the thermostat acts as a valve to prevent coolant from circulating through the radiator, to quickly warm up the engine. Then when the coolant reaches the thermostat temp it opens to allow the coolant to be circulating through the radiator. Once this occurs (open loop), the thermostat stays open and has no other effect on operating temp.
Luis350
El Paso, Tx
Luis
2019 GT350
That's a good way to do it, but again it won't do much. If you're doing anything more than just putting around town or idling, the 170* tstat won't do much even with the fans on earlier. You need more cooling capacity to reduce CHTs. That would be a bigger radiator, hood venting, radiator ducting etc.
So I do have a hood vent, I am getting a bigger radiator and then the t-stat to assist. I don’t have heating issues while putting around town when the temps aren’t 100+ but when I’m doing doing 5-10mph in traffic there isn’t much airflow
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Hood vents do help. You may or may not need them. I took off the rubber seals on the sides of the hood, leave the one in the rear. This was all I needed to make 20 min sessions.
Demonic
Boston
GT350R
We know what sarcasm is. There was nothing in your post to clearly indicate it, and even though I suspected it I didn’t want to brush off someone who may have genuinely been asking the community how part of their car works. You could have seriously been saying you learn something new everyday and asking why it doesn’t affect running temp. Then because your writing didn’t convey your sarcasm as clearly as you envisioned you ridiculed two people who tried to help when you asked.
Luis350
El Paso, Tx
Luis
2019 GT350
So…..can someone point me in the direction of this Mishimoto thermostat, I’ve looked for it but couldn’t find it.
Greg35
Oklahoma
Greg
' 18 GT350
@LOUIS350: Ck out the Reisch 170° thermostat. It is offered by Lethal Performance I see.
Luis350
El Paso, Tx
Luis
2019 GT350
I seen that one one but was looking for a mishimoto one. If I can’t find it I’ll go with the Reisch one
K4fxd
NKY
I have the Reisch, works fine.
EFI
Masshole central
5.Br0
It looks like you're dead set on doing this, which is fine. But I (along with a few others on here) have already warned you that just doing this alone is not going to do anything for your cooling issues that you mentioned in one of your posts: "I had my car go into limp mode while racing".
Just wanted to put that out there so you have the right expectations of this mod.
K4fxd
NKY
He is also installing a larger radiator. Larger rad plus lower temp T-Stat = cooler running car.
