Fuel doesn't change airflow. It's the other way around. Airflow is airflow. What the engine does with it (spark advance, fueling and cam timing) is what makes the difference in power.I wouldn't get to hung up on car to car airflow numbers. Comparing on your own to see the increase from each mod can be useful but keep in mind its only as accurate as the calibration it is derived from (flow bench or fuel trims? ). You can put fueling errors into the maf curve and artificially increase or decrease it. If the pump gas or e85 has a few points less ethanol than what the tune is expecting, you can easily add or subtract 5% to 10% to the maf curve to get trims correct. That's quite a bit of lb/min up top!
Yeah, I am well aware of variables. I have quite a bit of this under my belt thankfully. I used MAF flow and Dragy App to dial in my 2016 Gen2 car - to where I went to the track once and went faster than anyone expected. Almost too easy when you do things properly.I wouldn't get to hung up on car to car airflow numbers. Comparing on your own to see the increase from each mod can be useful but keep in mind its only as accurate as the calibration it is derived from (flow bench or fuel trims? ). You can put fueling errors into the maf curve and artificially increase or decrease it. If the pump gas or e85 has a few points less ethanol than what the tune is expecting, you can easily add or subtract 5% to 10% to the maf curve to get trims correct. That's quite a bit of lb/min up top!
The lb/min on the maf curve is the variable that gets moved for a given period(hertz). Its not the constant when a tuner uses the fuel trims to adjust the maf curve. within the ecu, its simply look up tables and formulas to output x amount of fuel. Actual airflow may or may not be accurate.Fuel doesn't change airflow. It's the other way around. Airflow is airflow. What the engine does with it (spark advance, fueling and cam timing) is what makes the difference in power.
It sounds like both cars would be a blast to rip on, out of curiosity did you get into any VCT changes with the manifold changes?Yeah, I am well aware of variables. I have quite a bit of this under my belt thankfully. I used MAF flow and Dragy App to dial in my 2016 Gen2 car - to where I went to the track once and went faster than anyone expected. Almost too easy when you do things properly.
I would never ask someone to show their MAF flow and claim my car is faster based on my airflow. I would also never compare data that is not close.
And yes, this Gen3 is an animal!
I absolutely 100% did. Here is a back to back pull, actually.It sounds like both cars would be a blast to rip on, out of curiosity did you get into any VCT changes with the manifold changes?
