GT350 & GT350R Parts Discussion
LevittownFordParts
LevittownFordParts
Worldwide
Benny
S550's!
I'm looking for rear sway bar links. For both the GT350 and GT350R. I know the GT350R links are shorter and it says so in my owners manual. But can you tell me what gt350 and gt350R part numbers and prices are please.
I show all Shelby versions using the same rear links
STABILIZER LINK - FORD (F2GZ-5C486-A)
List Price: $12.95
You Save: $4.01 (31% off)
Sale Price: $8.94
I also just verified 2 VIN's and they show the same as well
-Benny
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
List Price: $12.95
Sale Price: $8.94
-Benny
That's the problem I'm having because the owners manual says they are 5/16" shorter on the R
LevittownFordParts
LevittownFordParts
Worldwide
Benny
S550's!
Voodooo
SE Michigan
Scott
http://www.ebay.com/itm/Ford-Mustan...2d2ce593:g:1okAAOSwLmVXENtP&item=361535169939
VS
http://www.ebay.com/itm/Ford-Mustan...67aef40b:g:ZaIAAOSw9uFW9GQg&item=152063374347
Not sure what to say. Its also interesting an owners manual talks about sway bar links??
-Benny
Yes sir in my owners manual it clearly states that the R front and rear spring rates and also the R rear sway bar link are 5/16" shorter.
Voodooo
SE Michigan
Scott
Also both of the cars you listed on eBay are not R vin numbers and the listing of the white one is a gt350. Not a actual R. Nor is the vin number.
LevittownFordParts
LevittownFordParts
Worldwide
Benny
S550's!
Son of a .... talk about misleading lol
Do you have an R VIN I can check real quick? I doubt there will be a different part number but cant hurt
-Benny
Voodooo
SE Michigan
Scott
1FATP8JZ6F5520015
Voodooo
SE Michigan
Scott
Thanks for the VIN but same links come up
Benny
Benny. I just thought about this. Can you check on the GT350 and GT350R rear sway bars please. I think that it's possible the sway bars may have a different end link hole location for the end links.
Thanks Scott.
Darkane
Alberta
2016 GT350 Base
Send me your email address and I will workup a quote for you
The front shows a unique part number and is available
https://levittownfordsupercenter.com/oemparts/FR3Z-17757-C
The rear shows to be the same as other models so this is either incorrect data or Ford is using the same rear impact beam as a std model.
-Benny
Hi Benny,
I've been conducting research on the rear bumper beam for the gt350R.
In my finds ALL gt350 models '16+ are the stamped steel unit from the other mustangs. However, the very limited 2015R does have the aluminum rear beam.
Can you see if the 2015 rear beam has a specific part number, with only around 37 cars sold that model year, it may be difficult. Ford did have it as standard equipment on the '15R.
Cheers and thanks.
LevittownFordParts
LevittownFordParts
Worldwide
Benny
S550's!
Thanks Scott.
Bingo!
FR3Z-5A772-E Stabilizer Bar-Rr Magnaride
FR3Z-5A772-G Stabilizer Bar-Rear SVT R Model
LevittownFordParts
LevittownFordParts
Worldwide
Benny
S550's!
Hi Benny,
Cheers and thanks.
Im showing the same for both 2015 and 2016 part# FR3Z-17906-A . Ford shows the weight at 15lbs if that helps any.
-Benny
Aarron_M
NY
2010 Honda Fit
Do you have links for purchasing the front and rear bumper beams for the GT350R? Those could be a nice way to cut weight.
