Spart
I would try 0 just in case, because the difference between 8 and 2 is switching two bits. You only want to be switching one bit.Went out to the car and the chime is back too normal with out touching it
On a 15-18 car maybe, but it seems like they might have done a shakeup with the as-built for the 19+ based on what you posted. I'd be curious to take a look at the rest of the as-built, will you PM me you VIN?I read that using a 0 turns off the tweeters but will give it a try tomorrow
SureOn a 15-18 car maybe, but it seems like they might have done a shakeup with the as-built for the 19+ based on what you posted. I'd be curious to take a look at the rest of the as-built, will you PM me you VIN?
Sure
I am glad people are still poking around on this, I have a 19 350 also, I will attempt the 8 and 0 in the AM and see how it does.
Quite a bit different there. Some the same.
Let us know what going from an 8 to a 0 does! I'm reasonably sure that's the ticket, but it's just an educated guess as this is all trial and error.
Have you been able to confirm that the engine noise is off, tweeters are still working and no impact on chime after switching from:On a 15-18 car maybe, but it seems like they might have done a shakeup with the as-built for the 19+ based on what you posted. I'd be curious to take a look at the rest of the as-built, will you PM me you VIN?
What is that????????????Anyone have any luck with the window global close on the 2019 Gt350?
chime is back to normal after key cycle tweets all work engine noise gone haven't noticed any thing diffHave you been able to confirm that the engine noise is off, tweeters are still working and no impact on chime after switching from:
ACM 727-01-01 10A0 F200 00D2
to
ACM 727-01-01 10A0 F800 00D2
...no other impacts? Thanks.
Edit: Sorry, to clarify, I am referring to a 2019 GT350, non-R.
