GT350 FORScan Tweaks
Discussion in 'Shelby GT350 Mustang' started by Epiphany, Aug 12, 2016.
  1. Tomster
    Tomster Beware of idiots
    First Name:
    Tom
    Vehicle(s):
    2 - '17 and 1 - '18 GT350 R's
    Feb 20, 2016
    8,559
    7,017
    0   0   0
    Does anybody know if forscan can limit rpm and mph? My key doesn't do that. Thanks
  2. mattlqx
    mattlqx Driver
    First Name:
    Vehicle(s):
    '99 F-250, '16 Focus RS, '17 GT350
    Aug 21, 2015
    Chandler, AZ
    2,410
    1,446
    0   0   0
    No, that's a function of the PCM tune.
  3. Tomster
    First Name:
    Tom
    Vehicle(s):
    Feb 20, 2016
    8,559
    7,017
    0   0   0
    Alright, If I go to pick up the car and it has more miles than when I dropped it off, am I able to scan and document the history over the last week?
    Can Ford with their diagnostics be able to scan and record the stuff that Forscan cant see?
  4. AMpowerJ
    AMpowerJ Well-Known Member
    Vehicle(s):
    2016 GT350 - Ordering ...
    Aug 20, 2015
    Blythewood, SC
    365
    235
    0   0   0
    Great thread! I read all 40 some odd pages but I haven't found what I'm looking for yet. Does anyone know if you can correct the speedometer for lower profile tires? The Whipple Flare tool does not support the GT350 so at this point I'm stuck.
  5. PencilGeek
    PencilGeek Well-Known Member
    First Name:
    Robert
    Vehicle(s):
    2017 GT350R HR278, 2008 BMW M3
    Feb 17, 2017
    Northern California
    225
    192
    Rating:
    100%
    1   0   0
    I haven't seen anything to adjust speedo. I stayed with almost identical circumference tires to make sure the speedo error was minimal. Not sure if you've already bought the tires; if you haven't, try to choose ones that keep the same circumference.
    BTW: Long time, no see since the M3 days. I still own mine, along with the GT350R.
    AMpowerJ likes this.
  6. MakStang
    MakStang Well-Known Member
    First Name:
    Makis
    Vehicle(s):
    A 2017 miraculous little beast
    Dec 11, 2016
    Greece
    1,678
    253
    0   0   0
    AMpowerJ and Tank like this.
  7. AMpowerJ
    Vehicle(s):
    Aug 20, 2015
    Blythewood, SC
    365
    235
    0   0   0
    That's awesome! Thanks. I'll give it a try.
  8. Etchhead
    Etchhead Well-Known Member
    Vehicle(s):
    17 GT350R
    Apr 15, 2017
    Portland
    246
    89
    0   0   0
    Has anyone figured out if you can lock out the exhaust flapper moving into loud mode? Headed to a noise limiting track (92 do Laguna) next week and would prefer not to limp past the sound booth.
  9. cking
    cking Well-Known Member
    Vehicle(s):
    17GT350AG/BS-MGW/UPR/ABLIP
    Dec 27, 2016
    852
    236
    0   0   0
    unplug them?
  10. JAJ
    JAJ Well-Known Member
    Vehicle(s):
    2016 GT350 Track Pack
    Apr 9, 2016
    Vancouver BC
    1,110
    747
    0   0   0
    That throws a code and disables Sport and Track mode.
  11. kartguy898
    kartguy898 Well-Known Member
    Vehicle(s):
    2016 Shelby GT350 / 2016 F150 FX4
    Nov 23, 2016
    Ottawa, Ontario
    115
    35
    0   0   0
    Not a forscan tweak, but I believe [MENTION=18007]mattlqx[/MENTION] posted about this somewhere along the way:
    To plug the inside exhaust pipe (to pass noise restrictions at track).
    Safety wire to the exhaust pipe rock hole.
    https://www.mcmaster.com/#5117t29/=189370z
  12. AMpowerJ
    Vehicle(s):
    Aug 20, 2015
    Blythewood, SC
    365
    235
    0   0   0
    Thanks [MENTION=27749]MakStang[/MENTION] and [MENTION=25607]Spart[/MENTION] !
    The code worked great to fix my GT350 speedometer issue with my 305/30/19 tires. FWIW, using the calculator which is awesome by the way, the hex number was 07E6
    Note that I got a checksum warning when I enter the new hex number due to the last 4 digits that do not change, but I went ahead with it and a new checksum was calculated.
    I also disabled the double honk and the seatbelt chime. Interestingly I didn't have to use codes for either, just a drop down for Disable on both and it worked like a champ.
    Spart and Tank like this.
  13. Etchhead
    Vehicle(s):
    17 GT350R
    Apr 15, 2017
    Portland
    246
    89
    0   0   0
    Yes, read that in TMO as well but saw another one where a member called Ford and they said it would void the warranty should something happen. A bit to risky for me!
  14. mattlqx
    mattlqx Driver
    First Name:
    Vehicle(s):
    Aug 21, 2015
    Chandler, AZ
    2,410
    1,446
    0   0   0
    Grain of salt there. All it functionally does is add a small amount of exhaust restriction. There's nothing instrumented that would tell them one way or the other.
  15. HotLap
    HotLap Well-Known Member
    Vehicle(s):
    2017 Shelby GT 350
    Sep 23, 2017
    SoCal
    81
    rb92, thanks for the information as I'm planning on upgrading the sounds (adding amp, speakers, etc) and had read on another forum that folks were getting interference due to the sound module in the GT 350! Sounds like this may be the answer, thx!!
    rb92gt likes this.
Loading...
Share This Page
