GT350 FORScan Tweaks
Discussion in 'Shelby GT350 Mustang' started by Epiphany, Aug 12, 2016.
  1. rb92gt
    rb92gt Well-Known Member
    First Name:
    Vehicle(s):
    2016 GT350 Cooled Tech
    Jul 23, 2015
    Ponte Vedra, FL
    588
    364
    0   0   0
    Keith, Not sure what button on the bottom you are referring to. I am probably missing something really simple here, I apologize. I edited my last post and added a couple pics.
  2. TDC
    TDC Well-Known Member
    Vehicle(s):
    2016 GT350, 2019 Challenger Scat Pack Widebody
    Jan 27, 2015
    Long Island
    2,129
    1,178
    0   0   0
    I had the same problem. After first saving my factory config. I restarted Forscan. I didn't revert to a previously saved configuration and when asked I did not save. After doing this it allowed me to make modifications and then I saved the modified config.
    Tank and rb92gt like this.
  3. keith58
    keith58 Well-Known Member
    First Name:
    Keith
    Vehicle(s):
    2017 GT350 RR Convenience
    Jun 9, 2016
    Atlanta
    209
    58
    0   0   0
    Try pushing the little play button in the bottom left corner of the screen.
    rb92gt likes this.
  4. TDC
    Vehicle(s):
    Jan 27, 2015
    Long Island
    2,129
    1,178
    0   0   0
    My buttons were grey'd out/inactive until I did what I described in post above. Since then everything has been working as expected.
    rb92gt likes this.
  5. rb92gt
    First Name:
    Vehicle(s):
    Jul 23, 2015
    Ponte Vedra, FL
    588
    364
    0   0   0
    THANK YOU
    You guys ROCK! Worked for me, thanks TDC and keith58. I needed to do exactly what both of you mentioned. Now have red splash screen, both axle/trans temp displays, and eliminated the damn double horn honk on exit.
    Thx, Ryan
  6. OP
    Epiphany
    Epiphany Well-Known Member
    Vehicle(s):
    Quick
    Oct 11, 2015
    Global
    3,756
    4,645
    0   0   0
    Great to hear Ryan. Good for you.
    rb92gt likes this.
  7. rb92gt
    First Name:
    Vehicle(s):
    Jul 23, 2015
    Ponte Vedra, FL
    588
    364
    0   0   0
    #337 rb92gt, Sep 18, 2016
    Instruction Summary
    [Disclaimer: I have nothing to do with any of these discoveries and take credit for none of them. I am simply summarizing what a bunch of geniuses/heros came up with in the prior 23 pages of this thread and other threads. I am trying to make this specific for the GT350 here.]
    1. Need laptop with windows operating system (make sure date and time are accurate on computer, if outside of extended license range it will not load the extended license, see below about getting extended license)
    2. Buy https://amzn.com/B006NZTZLQ OBDLinkMXBluetooth (best connection, wifi prone to disconnections)
    If your windows computer does not have bluetooth, also buy https://amzn.com/B009ZIILLI
    3. Download forscan http://forscan.org/download.html (to windows computer you will make mods with)
    Choose "FORScan version 2.3.9 (or whatever the latest version is at the time) beta for Windows - free." Do not use Wine version. Will need extended license version to make modifications
    4. Sign up for forum http://forscan.org/forum/ucp.php?mode=register
    5. Wait for registration email from FORScan
    6. Obtain extended license http://forscan.org/forum/extlic.php
    7. Open FORScan and Click bottom Left "About" button to load license, when successful should read, "Extended License. Registered to..."
    8. Plug OBDMX into port
    9. Key On, Engine Off. Car should have a full battery and DO NOT let battery get below 11.4V, risk damage. I spent over an hour connected with no battery drain problems. If you have a goal of what you will modify before you connect to car it shouldn't take more than 15min from here on
    10. Start forscan on windows computer with bluetooth
    11. Click "connect to vehicle" at bottom
    12. Click left "Configuration and Programming button"
    13. Click on APIM, IPC, BdyCM, ACM (all AS BUILT) or RCM (not AS BUILT) depending what you want to modify:
    Module Address Value 1 Value 2 Value 3 Effect Model Year Package
    APIM 7D0-02-01 5553 0602 C04A Mustang GT Nav Anim. All Tech/Conv/Elec
    APIM 7D0-02-01 5553 0702 C04B Gray GT350 Nav Anim. All Tech/Conv/Elec
    APIM 7D0-02-01 5553 0902 C04D Red GT350R Nav Anim. All Tech/Conv/Elec
    APIM 7D0-02-01 x5xx xxxx xxxx Stock operation for no NAV in motion
    APIM 7D0-02-01 x7xx xxxx xxxx NAV in motion enabled/Sirius Traffic becomes disabled (didn’t work for me,
    still cannot enter addresses into NAV while in motion)
    IPC 720-06-01 7F6D 0664 9E22 No Axle or Trans Oil Temp Display All
    IPC 720-06-01 7F6D 1664 9E32 Axle Oil Temp Display All
    IPC 720-06-01 7F6D 8664 9EA2 Trans Oil Temp Display All
    IPC 720-06-01 7F6D 9664 9EB2 Both Axle and Trans Oil Temp Display All
    BCM 726-32-01 0A01 0000 006B Entry Lighting Disable (Dark Car Mode) 2016 Track
    BCM 726-32-01 0A01 0100 006C Entry Lighting Enable 2016 Track
    BCM 726-41-02 0000 0001 0172 No Horn Exit When Running 2016 Track
    BCM 726-41-02 0001 0001 0173 Double Horn Exit When Running 2016 Track
    BCM 726-41-02 0000 0000 0070 No Horn Exit When Running 2017 Conv
    BCM 726-41-02 0001 0000 0071 Double Horn Exit When Running 2017 Conv
    ACM 727-01-01 1801 C000 0009 Engine Sound Enhancement Disable 2016 Tech (didn’t work for
    me, I also tried 1801 3808 0089 and 1801 3008 0081 with no change. What finally worked to disable fake sound was 1801 F808 0049)
    ACM 727-01-01 1801 3A08 008B Engine Sound Enhancement Enable 2016 Tech
    ACM 727-01-01 D800 D000 00D8 Engine Sound Enhancement Disable 2016 Track
    ACM 727-01-01 D800 2A00 0032 Engine Sound Enhancement Enable 2016 Track
    ACM 727-01-01 1850 F000 44CC Engine Sound Enhancement Disable 2017 Conv
    ACM 727-01-01 1850 FA00 44D6 Engine Sound Enhancement Enable 2017 Conv
    RCM Enable/Disable Seatbelt minders (can also do it manually without needing FORScan, see below)
    14. Hit play button on bottom to show codes in the category from step 13.
    15. Make modifications to codes as desired (Write down your original codes in case you want to ever revert changes)
    16. Click write. Follow instructions given to cycle "key on engine off" / "key off engine off" if needed.
    17. Hit stop button on bottom.
    You can also turn off/on the seatbelt minders per the owner's manual page 31 as follows: Key on engine off, then wait until seatbelt light turns off on dash. Once light goes out, wait 5 seconds, then slowly plug/unplug seatbelt three times. After the third time the light will come back on, then plug/unplug one more time. Seatbelt light will now flash to confirm. Repeat on other seat. Repeat to turn back on if desired.
    For forscan detailed instructions with pictures (not GT350 specific): http://www.mustang6g.com/forums/showthread.php?t=61773
    Mystic_Cobra, Epiphany, ldp82 and 7 others like this.
  8. keith58
    First Name:
    Keith
    Vehicle(s):
    Jun 9, 2016
    Atlanta
    209
    58
    0   0   0
    Awesome! Getting rid of the double honk alone was worth the price. I disabled the sound enhancement too and feel the car has much less drone.
    rb92gt likes this.
  9. shelbyman
    shelbyman Well-Known Member
    First Name:
    Sandy
    Vehicle(s):
    2016 GT 350 Track Package White w/blue stripes
    May 6, 2015
    Huntington Beach, Ca.
    337
    81
    0   0   0
    You are right about great and painful. I'm reading it all and trying to follow it along but have exactly NO clue...:headbonk: All I want to do is default my exhaust to sport mode. :shrug: Just hate that I have to do that every time I start the car.
  10. stang302
    stang302 Well-Known Member
    Vehicle(s):
    2016 GT350
    Feb 19, 2016
    139
    62
    0   0   0
    I'll make it easy for you. There is currently no publicly known way to accomplish that. And PLEASE, someone correct if I'm wrong.
  11. OP
    Epiphany
    Vehicle(s):
    Quick
    Oct 11, 2015
    Global
    3,756
    4,645
    0   0   0
    You are correct.
  12. Bahndvr
    Bahndvr Roushcharged
    Vehicle(s):
    '16 Roush Warrior Mustang
    Jul 4, 2014
    Germany
    992
    104
    Garage Profiles:
    When I try to obtain the extended licenses (on FORScan) I get an error that says 'Hardware ID is not entered or incorrect', what goes there?
  13. rb92gt
    First Name:
    Vehicle(s):
    Jul 23, 2015
    Ponte Vedra, FL
    588
    364
    0   0   0
    #343 rb92gt, Sep 30, 2016
    I believe there is a place on the forscan site to get the hardware ID code, I can't remember exactly where. Let me look around a little and I will let you know if I find it. Make sure you are using the computer that you will use to connect to the car, as the hardware ID is unique to each computer.
  14. Bahndvr
    Vehicle(s):
    Jul 4, 2014
    Germany
    992
    104
    Garage Profiles:
    I dug around but couldn't find it. It is probably right in front of me.
  15. rb92gt
    First Name:
    Vehicle(s):
    Jul 23, 2015
    Ponte Vedra, FL
    588
    364
    0   0   0
    Found it! So once you have forscan on your computer, open the program, click the steering wheel with the question mark in the middle at the bottom left of the screen, you will see the hardware ID and there you can click copy to clipboard, then paste where it's needed.
    If you have trouble go to the forscan website, click "board index," then "general and support forum," then "standard and extended licenses for windows," lots of info there to help you with screenshots of what I explained above.
    Bahndvr likes this.
Loading...
Share This Page
