Trackaholic
Plus, you know, they look bad-ass.
That counts for a lot!
-T
-T
Ya but compare that price to the typical 9 to 10k price options you see on a lot of exotics and in reality it's like half price. Still stupid expensive for brakes but half price non the less.For 32lbs in weight savings and the slight increase in braking isn't enough to out weight the the $5,700 price tag. You can buy SS brake lines, better brakes and fluid and come close. Not to mention that a carbon fiber driveshaft with net you pretty close to the 30lbs range in weight savings and that's only $1,100.
Don't get me wrong, they look awesome and I wish I had them. I just feel like $5,700 can be better spent to improve the whole car.
Considering the price is only for the fronts, they're actually probably more expensive than the options on exotics. However, exotic's options may be priced a little better as the OEM saves having to install steel brakes if they are optioned with the ceramics.Ya but compare that price to the typical 9 to 10k price options you see on a lot of exotics and in reality it's like half price. Still stupid expensive for brakes but half price non the less.
Not sure they are available yet Sir.Why not go ceramic back too?
OP can you please send a link to all the parte that you bought to instala the kit?So I bought the RacingBrake kit...
It looks like the hats and discs are identical for the LH and RH side. Depending upon which side of the disc the hat is mounted to, determines if it's a LH or RH rotor (for the directional cooling). Neat concept.I also found the website offer two piece iron rotors for Gt350. Do they share the same aluminum hats?
http://www.racingbrake.com/RB-Front-Two-piece-rotor-Ford-Mustang-Shelby-GT3-p/2568.htm
70% of braking force happens up front. Mercedes does carbon front iron rear on some of their AMG cars.Why not go ceramic back too?
It's all in the kit:OP can you please send a link to all the parte that you bought to instala the kit?
Rotors, pads, lines, hubs, calipers?
