S140
Hi - not very mechanically minded but thanks for the above, car is still with the dealer. They initially replaced the sump gasket as the oil was dripping along the rear half of the pan.First things first, although your car may have been registered in 2018, it is actually a "17" in Mustang talk. An '18 has a completely different engine, known as the Gen 3. Your engine is a Gen 2.
OK, back on topic.. you may be able to diagnose this yourself? I'm not sure how mechanically minded you are, so I'll simplify how I explain this.. On top of each cylinder bank there is a large flat black plastic cover. These are the cam covers. With the engine cool or cold, run your finger around the edge of each cover. The joint where the bolt onto the engine should be dry.
If you find any wet areas, particularly around the rear this MAY be your problem.
If your dealer changed the sump gasket because he thought that was where the oil was coming from, it would have been apparent as there would have been oil down the sides of the sump and around the joint?
If he is now going to remove the starter to look for oil on the "flywheel", (Your car doesn't have a flywheel BTW, it has a drive plate, or flex plate) this may tell him nothing, as more often than not the oil doesn't get onto the flywheel if the rear seal is gone.
Another point to check, is the oil leaking from the cooler and blowing back onto the bellhousing?
One other point.. is this engine oil or transmission oil?
Update today that they have removed the starter and there is a trace of oil by the crank seal, they have cleaned it and will run it tomorrow and remove starter and check again to see if there are any further traces. I assume it will be the crank seal but they are trying their best to avoid having to replace it!
ford customer care now involved which has helped move them on.
