GT 350 engine/exhaust rattle on warm start
blkguyblk5.0
Cleveland, OH
2017 Shelby GT350, 2019 Ducati V4S Corse
raiderjatt02
Bay Area, CA
Jessie
2016 GT350 - Track Pack; 1995 GT - Saleen Clone
i honestly wish it was that since that’s an easy fix. The noise I hear is only on warm starts for a few seconds. It never happens on cold starts nor is there any noise when the car is moving so I don’t believe the video describes my situation. The symptoms described by @GoesTo11 and @raiderjatt02 are my exact symptoms.
Try doing what I do next time you take it out and see if it stops it. Obviously it isn't a "real" solution but I'm curious if it stops that sound for anyone else too. Like, if I take it out to the store, when I park it I blip the throttle then shut it off. Go inside the store, come back out about 30-40 minutes later and start it back up. No rattle. If I don't blip the throttle before turning the car off, the rattle is there almost every time on a warm start. Sounds like the timing chain tensioners to me so my gut is telling me that by blipping the throttle before I shut it down, the small spike in oil pressure keeps it lubricated long enough to get rid of the rattle on the next start up.
Fuck if I know. I'm not much of a mechanic but it makes sense in my mind. And it's been doing this for the past 3 years for me. 🤷‍♂️
blkguyblk5.0
Cleveland, OH
Interesting. I’m going to give this a try
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Mine did it cold, sounded like a rod knocking. Turned out to be a loose clamp on the exhaust.
blkguyblk5.0
Cleveland, OH
Holy shit this worked for me! Little throttle blip before shutting car off eliminates the noise on the next warm start.
raiderjatt02
Bay Area, CA
Jessie
haha nice! Glad to know I'm not crazy. Now....I'd still probably get it checked out one day but at least this is something you can tell the techs when you take it in. I'll probably get it checked sometime before my warranty is up but I'm not in a rush since it's been like this for a few years.
blkguyblk5.0
Cleveland, OH
Thanks for your reply. At least I have a starting point
barstowpo
Witness Protection Prog
Helena, MT
Gordon
2016 DIB GT350 Tech/Track hybrid, 2016 FPRS Car#17
I started having this issue on the second day at Auto Club Speedway. I tried raiderjatt02's solution and it worked almost every time. The only time it rattled a little bit momentarily but it was a lot better than before. I took an oil sample for analysis and I changed the oil. We'll see if it does it at Hallett next week.
blkguyblk5.0
Cleveland, OH
The issue for me occurs at every warm start even during normal driving. Not sure if you waa insinuating that it only happens during track days.
barstowpo
Helena, MT
Gordon
I have 2 2016 GT350's. Only one car is doing this and it is the one I am tracking now. It doesn't get driven much on the street so for me it only occurs at track days. I assume it would do it if I took the car to Walmart or anywhere else but I don't really do that. I also had one prior weekend on the oil so I don't know if that factors into it or not. I was amazed raider's solution worked. He is not crazy.
raiderjatt02
Bay Area, CA
Jessie
It happens to me on track and during normal driving to the local Walmart. Only happens if the engine gets up to normal operating temps. Never does it on cold starts or if I make a short trip that doesn't get it fully warmed up.
blkguyblk5.0
Cleveland, OH
Bingo. Same for me about the behavior related to temperature. Took it to a local shop and of course it doesn’t do it when the mechanic takes a look:cwl: . Really bugs me that there is no known cause for this.
raiderjatt02
Bay Area, CA
Jessie
If you take it to the shop again. Let it sit for about 45 minutes before starting it back up. It doesn't do it to me if I turn it off, then turn it back on a few minutes later. It usually does it after it's been up to temp, then turned off for about 45 minutes to an hour. Sometimes it'll happen if I turn it on after just a few minutes but I've noticed that after sitting for 45 minutes, it's pretty much guaranteed to make the sound if I didn't blip the throttle when I shut it off.
blkguyblk5.0
Cleveland, OH
I am curious how many miles you have on your 350?
raiderjatt02
Bay Area, CA
Jessie
Just about 25,000. Had the car since 2016 with 2.6 miles on it. Still doesn't burn a drop of oil and it gets driven pretty damn hard.
