ice445
- Apr 13, 2020
- Salt Lake City, UT
- Ryan
- 2020 Mustang GT 6MT
I just did this, I'll chime in tomorrow if it worked. If so, that's the easiest fix ever. Way better than pulling everything apart. I used two square pieces of rubber insulation folded over and tucked it down above the left most vent in the corner and the center one.Looks like you have the same vent and gauge rattle I (and many others) had. VERY EASY to fix. I did it with a rubber washer I had laying around. Cut a small piece, and shoved it above (at 12 o'clock) the vents and gauges with a thin plastic trim tool, and problem solved 100%. I actually tried to fix it from the inside, when I installed the GT350 gauges, putting foam tape all over, and didn't fix it. So no need to remove anything at all. Hope this helps.
