Graph of first 6 gears of my 10R80.
LSchicago
Illinois
Lloyd
2018 Mustang GT/A 301A 5.0
Did a graph of my Mustang shift points, and RPM drop per gear for the first 6 gears. It can finish the 1/4 mile in 6th gear by holding the RPM's a bit higher at the finish. Last time out was 138MPH in the 1/4 (3500 DA), but should be 140+ next time out. 8,000 RPM would be 144mph, so as long as I stay under that, I should be able to cross the line in 6th.
Can't wait for cooler/better weather.
qtrmiler2
streator,il
greg
2018 mustang gt pp1
Lower the shift point.It may be losing power at that rpm.8000 rpm is high.Just curois.
qtrmiler2
streator,il
greg
2018 mustang gt pp1
When mine was tuned the shift point was 7800 car lost et and mph.Went back to stock shift points and was quicker and mph was greater.18 pp1 stock on e85.
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
He has a Procharger so pretty sure he can pull that RPM vs stock engined car...
LSchicago
LSchicago
Illinois
Lloyd
Stock shift point is 7400, but I seem to see 7500 consistently. I just don't want it to hit 7th on the strip. Procharger keeps adding more boost well past 7500. I may need 3.31's.
LSchicago
LSchicago
Illinois
Lloyd
I'm curious to see what my car will do with 3.15's. I specifically went with them with future boost in mind.
I just graphed that out, it will hit 152 in 6th at 7500 RPM with 27.4" tires and 3.15 gears.
LSchicago
LSchicago
Illinois
Lloyd
3.31 would be optimal for my setup, unless I could find some taller 19" drag radials. I really don't want to put a drag pack on it.
LSchicago
LSchicago
Illinois
Lloyd
I will only run The One True Road Tire: The Michelin Pilot Sport 4S :giggle:
I wish they would make a 305/35/19.
I can't run Michelin's. The NT555RII Drag Radials tires barely hook enough on mine. 305/40/19 would be perfect for me. But no one seems to make those.
EFI
Masshole central
5.Br0
Why are you so worried about going into 7th? It's an automatic and a very fast shifting one at that, you won't lose any discernable amount of time with on more near instantaneous shift. With a manual and not power shifting, I can see wanting to stay in the lower gear and forgo an extra time consuming shift. Also you have a ton of power from the blower, so it's not like you're going to bog down and loose momentum by being at 6000rpm in 7th.
I say try it first before going with different gearing. See if it slows you down doing the extra shift.
LSchicago
LSchicago
Illinois
Lloyd
LSchicago
LSchicago
Illinois
Lloyd
I don't want the added stress on the clutches of being at 1:1 if possible.
br_an
Boise, Idaho
Bran
2016 Shelby GT350, 2020 Ford F150
Picture a graph from a bowl of oatmeal. Same thing :crackup:
