RPI Designs
- Nov 18, 2014
- Salem, Ohio
- Website
- www.rpidesigns.com
- 2015 Mustang GT - Test Mule
2015 2016 2017 Mustang 5.0 85mm Throttle Body $388.63 With Code PHIL5 At Checkout.
The new Grams 85mm Drive-By-Wire Electronic Throttle Body for 2011-2017 Ford Mustangs 5.0 and F-Series Trucks 5.0 is a perfect upgrade for the factory Ford 80mm throttle body; delivering a 15% increase in airflow. Each throttle body includes all new components including a CNC machined billet 6061-T6 aluminum housing with a precision-honed oversized bore, a high-torque servo motor, and a proprietary Non-Contact Hall Effect TPS sensor. To ensure the best performance, throttle response, and driveability, each TPS sensor is calibrated to meet the specific requirements of the vehicles engine management system. The Grams electronic throttle body is an ideal solution for both modified and stock engines with increased airflow demands.
http://www.rpidesigns.com/shop/item.aspx/2015-2016-2017-mustang-5-0-85mm-throttle-body/
Note:
15% increase in airflow over the stock 80mm Throttle Body
Precision Honed Oversized 85 mm Bore
Aluminum Throttle Plate
Factory Programmable Non-Contact Hall Effect TPS
Optimized TPS Response Curve
High-Precision Servo Motor
Works with OEM and aftermarket intakes
Wiring Harness Adapter included
MUSTANG6G Forum members save with code PHIL5 At Checkout.
See this and many more parts at http://www.rpidesigns.com/shop/
Note:
