jbostian
- Oct 21, 2018
- Indianapolis, IN
- Jamie
- 2015 Ford Mustang EcoBoost Premium
That was a good article. Thanks for providing the link.
I asked CP-E over FB messenger about built engines/shortblock for 2.3L and they said it’s in the plans.
For comparisons sake, keep in mind these dyno runs were made using the STD J607 correction factor, which gives the most favorable numbers. SAE J1349 is the more common correction factor and would give a little lower numbers.
Comparing dyno results (to less than 3-5% deviation) is pointless unless it's the same car, same operator, same day/time, same atmospherics.keep in mind these dyno runs were made using the STD J607 correction factor,
That has been in their plans for a minute, but I will definitely move up to one of those given the next three statements are all true
1 - I exceed the mileage allotment for the powertrain warranty
2 - I pay the car off
3 - I still own it
lol but I am definitely a big fan of and supporter of CP-e
Out of curiosty, how do you know?
It's in the top right corner of your dyno sheet, CF: STD.That has been in their plans for a minute, but I will definitely move up to one of those given the next three statements are all true
3 - I still own it
If your using a correction factor on the dyno, the atmospherics don't matter, as the correction factor takes the uncorrected HP and torque numbers and mathematically changes them to the standardized atmospherics of the given correction factor. With the STD/J607 correction factor, the parameters are 60°F at sea level, 29.92", and 0% humidity, if I recall correctly. The SAE/J1349 correction factor, the most commonly used, uses 77° F at sea level, 29.92", and O% humidity.Comparing dyno results (to less than 3-5% deviation) is pointless unless it's the same car, same operator, same day/time, same atmospherics.
