Ricker
- Feb 16, 2019
- South Florida
- Ricky Rick
- Mustang
Here is my setup.
Damn 8200?? Did you have to do OPG? Did you modify the PMAS to work with the VMP? OP couldn’t get it to fit.I ordered Fore fuel rails for my 18 CJ setup. The rich codes hopefully can be tuned out. I didn't have those.
You are likely to have more misfire codes on startup with the CJ, but nothing major.
I used the PMAS with the VMP 69 and BMR engine brackets that lower the motor on the stock mounts. No NVH.
3k - 8200 is a ton of fun. You'll get it sorted.
Did your tuner give you a base tune for the FP intake with CJ?Ok everything has been installed, including Ford Performance cold air intake. The intake package by itself won't work because the housing doesn't fit a 2018, so I reused my JLT housing and it fit perfectly.
However, the car has some issues. It will start up and then immediately die. The only way to get it to stay idle without shutting off is to raise the revs immediately after startup and hold it for a few seconds before bringing it back down. We thought it was just the computer needing to learn but the car will always start up and die regardless if it idles for 5 minutes or after a 15 minute drive.
I'm also getting the below check engine codes:
P0172 - System Too Rich
P0175 - System Too Rich
P050A - Cold Start Idle Air Control System Performance
I was able to drive the car home. It otherwise seems to drive normal, other than whenever the car is shut off and turned back on, it will just idle and die unless I hold the revs up. Those check engine lights wont go away either.
I did some datalogging and sent the logs to my tuner, however they're at some kind of mod nationals event so I'm not sure when they'll reply. Anyone seen this issue before after a cobra jet install?
At first I threw my purse at it, then I picked up my change and cut it lol!Damn 8200?? Did you have to do OPG? Did you modify the PMAS to work with the VMP? OP couldn’t get it to fit.
you still have misfire codes even after tune? Or ate you saying before the tune it will throw themI ordered Fore fuel rails for my 18 CJ setup. The rich codes hopefully can be tuned out. I didn't have those.
I got a base tune for the CJ intake, VMP throttle body and PMAS intake. Only thing that changed was the PMAS intake swapped out for the Ford CAI.Did your tuner give you a base tune for the FP intake with CJ?
That’s your issue. Pretty sure there is a difference with the MAF readings due to the difference of the pipe diameter.I got a base tune for the CJ intake, VMP throttle body and PMAS intake. Only thing that changed was the PMAS intake swapped out for the Ford CAI.
Still waiting to hear from the tuner.
On E/CJ compared to the stock intake on E, I've found an increase in misfire codes, especially on startup. Nothing major, but its there more frequently. Maybe its due to the deleted runner plates in the CJ.you still have misfire codes even after tune? Or ate you saying before the tune it will throw them
Why don't more people recommend these brackets versus lower mounts when doing the CJ? Seems the way to go to prevent increased NVH.I used the PMAS with the VMP 69 and BMR engine brackets that lower the motor on the stock mounts. No NVH.
J,Why don't more people recommend these brackets versus lower mounts when doing the CJ? Seems the way to go to prevent increased NVH.
