luc
They don’t inspect them. Just check for an error codeThey inspect the crank and bearings, so if yours are not damaged or out of spec, they change your oil and give you a 10/150,000 engine warranty
Most manufacturers allow for up to 1qt per 800 miles before deeming it to be an issueIf your consuming two quarts every 5k miles. you have something else going on besides just using 5w-20. Yes, a little here and there is ok, but 2 quarts means something is not fully right and its not just the oil you are using. I've had 4 S550's and none of them have even consumed 1/4 of a quart during a 5000 mile oil change.
It’s pretty on brand for GM to issue a band-aid and not fix the actual problem.That’s a pretty massive recall. Interesting that they are trying to bandaid the issue as well with thicker oil for those who don’t have the issue yet.
I have some that in the garage under a different brand name ...
Correct, but a thicker oil will cushion the bearings a bit better and extend their life a bit longer than thinner oil.The problem is the bearing supplier, not the oil weight.
All they're trying to do is limp these engines to the warranty finishline. If they can save a few thousand engines from having to be replaced then they saved themselves millions of dollars.Interesting that they are trying to bandaid the issue as well with thicker oil for those who don’t have the issue yet.
????It’s pretty on brand for GM to issue a band-aid and not fix the actual problem.
https://gmauthority.com/blog/2022/08/gm-issues-fix-for-gmc-terrain-excessive-headlamp-glare-recall/
Oh I totally understand. Just stating the root cause is poor choice to change suppliers.Correct, but a thicker oil will cushion the bearings a bit better and extend their life a bit longer than thinner oil.
They had a bearing that worked and didn't fail. Then switched suppliers. Then the bearing failed.????
Sure, Gm choose the cheapest way to deal with the issue
But if that solution do fix the issue, what’s the problem?
As a matter of fact that show that they are pretty smart
I was specifically replying to the post regarding the headlamp issue, not the engineThey had a bearing that worked and didn't fail. Then switched suppliers. Then the bearing failed.
It's a band aid.
A sticker will not last the life of the car. Especially down south. This will just be a problem down the road again. It’s not a fix.????
That’s a fallacy, Stickers can easily last the life of a vehicle. Most graphics, stripes, nameplates, etc, are nothing more than stickers and just go to a junkyard to verify that most of the time they will outlast a vehicleA sticker will not last the life of the car. Especially down south. This will just be a problem down the road again. It’s not a fix.
