Gesi gsport2 vs 2020 gt500 cats
JoeCee
Milwaukee
Joe
13 GT500
I’m looking to do 9psi boost setup and want to run stock manifolds with either the 2nd gen gesi gsport cats for boost or 2020 gt500 cats. 93 octane no track, drag racing or 60-130 runs. Which would be better. I can get a very low mile set of gt500 cats for $500.
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
At 9 psi you might as well run the GT500 ones and save your money. If you decide to crank up the power down the road, you can switch to the GESI Gen2 cats then, since you won’t be running stock manifolds then anyway.
beefcake
Bethel
2018 Ford Mustang
most of the gt500 guys upgrade as well, most of the guys are doing the lth with ecof or kooks green
Joshinator99
Massachusetts
Josh
They’re not running stock manifolds at that point. OP specifically said they wanted to keep stock manifolds and he’s only at 9 psi. Upgrading the cats at that point is definitely overkill.
Unless you turn up the boost, in which case I’m with you. :)
