markmurfie
Its a pretty crude method, but as you can see the effect on cylinder pressure between compression and boost is an exponential one.huh? you cant compare compression to boost psi LOL!!
yes I know well what the engine differences are between the gen2 and gen3 coyote engines are ive owned both.
I will agree with you on the compressor map info.
Same reason why it drives me absolutely bonkers when vendors say "custom spec cams" without releasing the specs.
Same goes for ported heads.
