Spart
I guess I should test it out at that RPM with the valves shut...I never had a problem with drone. I assume you changed the exhaust?
On my old GT, it could definitely get droney at that RPM with the Borla.
Pretty sure the valves are going to be shut if you're in 6th gear cruising. They open in 1-5, but close in 6th AFAIK.I guess I should test it out at that RPM with the valves shut...
Right, I'm saying I should test it out in 5th.Pretty sure the valves are going to be shut if you're in 6th gear cruising. They open in 1-5, but close in 6th AFAIK.
Mike,John can you tell me what year your car is and does it have the cross traffic and blind spot detection system [ don't know if it will make a difference ], I have bought a new 2019 GT350 and it has it. I was wondering if a gear change would cause a problem.
Why I ask and I know it maybe different on the GT350, but I just traded a 2019 Bullitt in on the GT350. I had changed the gear to a 4.09 in it and it screwed up everything lol. Before I got out of the driveway I got default for cross traffic, blind spot, hill side assist, couldn't change drive modes and by the time you got to about 30 mph you would get the wrench in the dash [ see service manual ].
Anyway long story short after talking with several places and FP, I could not find any fix for it [ maybe a tune ]. I did try changing the hex in the BCM but that didn't do anything. So I had to change it back to the 3.73. Cleared the codes again, everything went back to normal.
I really liked the 4.09 in it and still have them and would love to put them in the GT350, but it would be really nice to know that it wouldn't be a problem like it was in the Bullitt before I did it.
Maybe someone else has changed theirs, like to here some feed back before I try it. Thanks
I may not find out anything else on it as I traded it in on the GT350.Mike,
My GT350 is a 2016 (Doesn't have the: blind spot detection) Honestly I have not heard of that problem before. What the heck...
I have had both 4.11, and 4.56 in my car with absolutely no problems throwing codes. I too could change the Gear Ratio setting in the BCM with Forscan, but did not affect anything.
Please keep us informed if you find out anything more on this subject.
Unless they figure out it’s changed.This mod should retain the power train warranty if no tune is required?
If anyone is interested I just changed the gear in my 2019 GT350 to 4.09 with no issues, just like John said.Mike,
