Gas Tank Sloshing/Front Wheel Whine
cosmo
Posts
1,770
Michigan
2005 Mustang GT
So I've already come across a few issues.
Base Ecoboost manual with the performance pack at 500 miles.
I've started to hear a whine coming from the front passenger wheel well. It isn't affected by braking, accelerating, or decelerating. Having the clutch engaged or not doesn't matter. The whine comes on anywhere between 10 - 20 mph, and stays pretty constant all the way up to 80. I'm not sure if this is a result from my winter Dunlop tires (but none of the other 3 are doing it), or a bad wheel hub. I've just emailed my salesman to schedule an appointment.
Also, seems like a baffle in my gas tank came loose. If i brake relatively hard, you can hear the gas sloshing around a lot. I don't remember this before, and I don't think my '05 GT had this. Anyone else hear their gas sloshing around? It's at 3/4 tank right now.
Advertisement
TurboAg
Posts
140
2015 EcoBoost PP 6MT
I started hearing a whistling noise when under throttle at around 500 mls in the ecoboost. It is most noticeable at low RPMs at take off when other noises are low. It almost sounds like it is coming through the stereo and it changes frequency with engine RPM. Can't figure out what it is though. Kind of sounds like a supercharger whine.
Nemesys
Posts
853
United States
Oxford White S550
Possibly could be bad grounding in the audio system. Be sure next time to shut your radios off to see if the sound goes away. If it does, you have your answer and can go to your dealer to let them know. If they dont help any audio shop can assist with installing an isolater.
TurboAg
Posts
140
Thanks for the idea! I'll have to check next time I drive. I'm pretty sure I hear it when the sound system is off though...
JimmyTwoTimes
Posts
3,298
New York
2015 GT Premium
In the Ecoboost the sound system is never off, since it's always piping in the fake cabin noise. Try pulling the fuse on the radio and see if the noise is still there.
BMR Tech
Gold Sponsor
Posts
5,127
Tampa, FL
www.bmrsuspension.com
Dion
My fuel sloshed like crazy...and it was very noticeable.
Now, it's even worse. No back seats, and a gutted trunk.
Damn.
Advertisement
119 - HP Tuners - 1
Advertisement
