A lot of this is to be expected when you run UHP summer tires at temperatures in the 20°s F.Hey Guys,
Really looking for a recommendation here.
I have the Ford performance track handling package installed on my 2016 GT. I use this car as a daily driver and drive aggressively.
The handling on the car feels worse then the car was stock. Basically high speeds on the freeway don’t really feel stable and even turning feels like the car losing grip so easily.
What inflation pressures are you running them at?I think the car just feels too stiff and it’s hurting the handling.
I'm not finding that size in MT street comps. Only 255/40-19 and 255/35-20.the tires setup is 255/35r/19 all around.
He said Nitto NT05 front and 555G2 rear, IIRCI'm not finding that size in MT street comps. Only 255/40-19 and 255/35-20.
Alex specifically mentioned the Mickeys in 255/35-19.He said Nitto NT05 front and 555G2 rear, IIRC
andthe tires setup is 255/35r/19 all around.
I’ve got Mickey Thompson Street Comps.
I run 275/35/19 nitto nt05 on a 19x10 wheel for the fronts and I run 305/45/17 nitto nt555rII on a 17x10 wheel on the rear or a 305/35/19 nitto 555rII on a 19x11 rear wheel
Alignment would be my first suspect.ditch the springs and get bmr sp083, steeda camber plates, j&m rear shock mounts and a good alignment by a performance shop.
Front: -1.2° to maybe -1.5° camber, 0.05° to 0.07° toe (toe in) per side, 0.10° to 0.15° total toeAppreciate the input, I may start with getting the alignment redone. It’s been over a year so definitely could be out of wack.
Any recommendations for alignment specs?
It’s a daily driver and I don’t track the car. I prefer some highway rolls every now and then. It’ll see the drag strip 1-2 a year.
Just looking for stability and good/fun handling around corners out on the roads.
I think the Ford Racing Track Pack recommended (track settings?) is:Appreciate the input, I may start with getting the alignment redone. It’s been over a year so definitely could be out of wack.
