The shocks and struts are the performance pack ones, which are marginal improvements over your base 18 dampers.Anything else the same?
Since this is supposed to be the same stuff from the pp1...The shocks and struts are the performance pack ones, which are marginal improvements over your base 18 dampers.
The 18 base are a good deal better than the 15-17 base. The PP is certainly a significant improvement but it's just not as big as it used to be. The rears are now monotube like the PP. A large portion of what you felt when driving the PP was tires, also.Since this is supposed to be the same stuff from the pp1...
What you are saying is....the PP1 suspension is only a "marginal" upgrade over the base GT?
I drove a PP1...i thought it was a noticeable difference in handling.
I mostly wanted the 1 inch drop while keeping the warranty in place ....a bit disappointing to hear that the pp1 and base are so close in spec.
Seems almost like a bit of false advertising on Ford's part.
When you look at their springs, they "strongly recommend" the upgraded dampeners. When you look at dampeners they "strongly recommend" the "upgraded" sway bars.
I am running 305s in rear and 255s in front.The 18 base are a good deal better than the 15-17 base. The PP is certainly a significant improvement but it's just not as big as it used to be. The rears are now monotube like the PP. A large portion of what you felt when driving the PP was tires, also.
Of course FP says they're strongly recommended . For the dampers it's definitely a good idea, as your stock ones wouldn't handle higher spring rates well.
Honestly there isn't really anything to worry about with warranty on suspension like engine or transmission stuff, assuming it's installed correctly. You could've gone with aftermarket stuff and kept your bumper to bumper intact, too.
Those are the same as a base GT ..How about the toe links
All GTs get the PP toe link.How about the toe links
The springs are not that much stiffer, barely at all, 3%, in the front and only 9% in the back. Only rear bar is a small amount stiffer. The dampers are certainly better and will provide the sense of less roll for certain. Tires on the PP make a HUGE difference in both grip and feel.My understanding is the springs are bigger, stiffer, and lower on pp1 (different struts/dampers) in addition to strut bar and k brace. I drove both and found the pp1 to be substantially stiffer with almost zero body roll compared to base suspension 18 GT. The brembo’s made it a no brainer.
