Ford Performance 2020 GT500 Oil-Air Separator
Discussion in 'Shelby GT500 Mustang' started by Grey03, Sep 18, 2019.
  1. Nolimits88
    Nolimits88 Well-Known Member
    First Name:
    Justin
    Vehicle(s):
    2014 GT500 2020 TO GT500
    Jun 29, 2019
    Upstate NY
    253
    168
    0   0   0
    Blue Oval back in stock with these, but they also raised the price up $25, plus the 10% coupon no longer valid.
  2. geoking
    geoking Well-Known Member
    First Name:
    George
    Vehicle(s):
    31,34,48 and 2019 Fords + a 58& 66 Chevy trucks
    May 18, 2019
    Huntsville , AL
    194
    233
    Occupation:
    retired
    0   0   0
    My oil separator from BlueOval was delivered today. It was shipped in the OEM factory packaging with an opaque white label over the Ford P/N label. I carefully pealed the covering label back . Here it is for those of you with interest. IMG_1619.JPG
    obspsd likes this.
  3. The Chairman
    The Chairman Well-Known Member
    Vehicle(s):
    ‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500
    Mar 18, 2016
    South TX
    716
    496
    0   0   0
    Any instructions included?
    Also: The FP Tech Line got back to me on my question whether this part would fit a Base GT500, or do we have to purchase the new cam covers?
    Their response adds to the confusion. Here it is exactly from an email: “No, just R.H. camcover. You can use the separator without the GT500 camcovers, but you lose the self draining feature and you’d have to get some stud bolts.”
    So I clarified my question back to them and await a new response.....
  4. geoking
    First Name:
    George
    Vehicle(s):
    May 18, 2019
    Huntsville , AL
    194
    233
    Occupation:
    retired
    0   0   0
    #94 geoking, Sep 25, 2019
    Yes a 12 page document . No. SKKR3V-6D600_AA Revision 2.
    "No part of this document may be reproduced without prior agreement and written permission of Ford Performance."
    Here's the basic overview...
    Remove the plastic coil pack cover, cut the red cable ties ( 2 each) on the harness and toss them as they have new ones for you to add back after you re route the coil pack wires to make room for the mounting bracket.
    Remove and toss the PCV valve. Remove the coil cover plug and add a tube with jamb nut. ( this is the drain )
    The separator box slides onto the mounting bracket that is mounted to 3 cam cover studs. Route the provided hoses from the kit to hook up everything. If you want to clean the wire mesh inside the separator...reverse the process and remove the separator from the car before disassembly for cleaning.
    If you decide to change your mind and remove the kit, purchase a NEW PCV valve and reuse old hoses.
    The directions offer up hints for direction of hose clamps for avoiding damage to other hoses as well as insuring clearance to reinstall the coil pack cover.
    Regards,
    George
    The Chairman likes this.
  5. obspsd
    obspsd Well-Known Member
    First Name:
    Keller
    Vehicle(s):
    2017 Mustang GT Auto Ruby Red
    Dec 1, 2018
    IL
    2,616
    1,929
    0   0   0
    V00D00 likes this.
  6. Strokerswild
    Strokerswild Shallow and Pedantic
    First Name:
    Vehicle(s):
    Stuff With Wheels
    Nov 7, 2014
    Southern MN
    3,973
    1,792
    Rating:
    100%
    1   0   0
    .....aaaaaannd major fail not letting us see the inside of the separator body.
    The GT/GT350 separator that the OP referenced works very well but is pretty small so it has to be emptied regularly. I'm betting the GT500 unit has a larger and more efficient "element" similar to the GT/GT350 unit (it's a weird piece), plus the self-draining bonus.
    I assume the cam covers are aluminum versus plastic, and that they are either painted or powdercoated.
  7. HoosierDaddy
    HoosierDaddy Well-Known Member
    First Name:
    Randy
    Vehicle(s):
    2016 GT Premium PP and a few others
    Jan 2, 2016
    5,177
    2,748
    Occupation:
    I could tell you but then I'd have to kill you
    Rating:
    100%
    2   0   0
    I didn't check the cost of the cover but is it possible to modify the cover already on a car?
  8. geoking
    First Name:
    George
    Vehicle(s):
    May 18, 2019
    Huntsville , AL
    194
    233
    Occupation:
    retired
    0   0   0
    #98 geoking, Sep 26, 2019
    HoosierDaddy likes this.
  9. geoking
    First Name:
    George
    Vehicle(s):
    May 18, 2019
    Huntsville , AL
    194
    233
    Occupation:
    retired
    0   0   0
    heres what it looks like: IMG_1626.JPG IMG_1625.JPG
  10. Jetnoise
    Jetnoise Well-Known Member
    Vehicle(s):
    2018 GT Premium PP1, 70 Shaker Mach 1 stroker, 1967 F/B 357W, 1968 302 Vert, 4I 85 5.0 B&M Blower
    Jun 27, 2018
    Raleigh NC
    1,219
    262
    0   0   0
    That thing looks purpose built! Like the others Ford makes.
    Bottom looks like it's almost multi-chambered
  11. geoking
    First Name:
    George
    Vehicle(s):
    May 18, 2019
    Huntsville , AL
    194
    233
    Occupation:
    retired
    0   0   0
    The plastic cap is to protect the threads and pulls off. ( trash) The Jamb nut and o ring let you keep the tube pointed in the correct direction , while enabling the tightening of the nut to seal the o ring on the cam cover.
  12. Epiphany
    Epiphany Well-Known Member
    Vehicle(s):
    I like to disassemble things.
    Oct 11, 2015
    Global
    4,986
    6,188
    Occupation:
    Philanthropist and ballroom dancer extraordinaire
    0   0   0
    ...aaaaaannd this was up on YouTube the same day but not linked here...
  13. Snoopy49
    Snoopy49 Well-Known Member
    First Name:
    Earl
    Vehicle(s):
    2013 GT500 and 2020 GT500
    Jul 24, 2019
    California
    2,426
    3,756
    Occupation:
    Retired
    0   0   0
    #103 Snoopy49, Sep 26, 2019
  14. The Chairman
    Vehicle(s):
    Mar 18, 2016
    South TX
    716
    496
    0   0   0
    Thanks — good info!
  15. obspsd
    First Name:
    Keller
    Vehicle(s):
    Dec 1, 2018
    IL
    2,616
    1,929
    0   0   0
    Haven’t seen you around here for a while!
    Epiphany likes this.
Loading...
Share This Page
