RPI Designs
- Nov 18, 2014
- Salem, Ohio
- Website
- www.rpidesigns.com
- 2015 Mustang GT - Test Mule
2015-2016-2017 Ford Mustang GT 5.0 MBRP Exhaust 3" Cat Back Dual Split Rear Race Version 4.5" tips BLACK COATED Now at RPI Designs.
PLEASE NOTE: THIS SYSTEM ONLY FITS THE REGULAR COUPE, NOT THE CONVERTIBLE.
Our Black Series performance exhaust systems offer a true murdered-out style without compromising on quality and performance. With fully sealed seams to resist rust you can count on this system to really hold up. The black coat finish is specifically formulated to withstand the extreme heat and abrasive conditions an exhaust system is exposed to.
Built to Perform
MBRP's performance exhaust systems are built to perform. Designed to maximize exhaust flow and minimize exhaust temperatures your ride will use less gas, last longer and perform better. Every system we sell has been built to the most exacting standards in the industry.
Dyno Proven
Your MBRP muscle car system has undergone countless hours on our in-house Mustang 1100 AWD-SE Chassis Dynomometer, hundreds of miles on road and track and numerous tweaks and modifications to get maximum performance. From the vehicle specific muffler design to the fully mandrel bent tubing to minimal bend degree angles, your MBRP performance system gets exhaust out fast. An MBRP performance exhaust system is the starting point to getting the most from cold air intakes, programmers, modules and downloaders.
Sound & Style
Performance is one thing but at MBRP we believe that appearance and sound are just as important. Every MBRP performance exhaust system has been specifically tuned to get the optimal sound from your ride. Civilized when you need it to be and seriously aggressive when you want it, it is all classic muscle car. With our stamped logo on the tip and our unmistakable styling, there's no question that you have the hottest performance exhaust on the road - MBRP.
Easy Installation
MBRP systems are as much fun to install as to drive with on your muscle car. Bolt-on, no weld design makes installation a no hassle one and a half to two hour project. Everything is direct fit to the OEM hangers and you get all the clamps and parts you will need, all in one box.
http://www.rpidesigns.com/shop/item...plit-rear-race-version-4-5-tips-black-coated/
PLEASE NOTE: No coupon codes can be used on Mustang MBRP Exhaust systems. Our prices are the best you will find and they cannot be discounted more. If a coupon is used, the order will be canceled and money refunded. Thank you.
Built to Perform
Dyno Proven
Sound & Style
Easy Installation
