Final Questions regarding 20x10 wheels 275/40
RoninRed
US
2016 GT Prem. (PP) Magnetic
First off, will 275/40 and 20x10 wheels fit upfront, and back?
Second off, will dropping the profile from 275/40 to 275/35 or 30 give any significant advantage?
I ordered the sve gt350 setup from lmr, for reference.
robwlf
phila
rob
17 lightning blue pp LFP 670
id run a 275/35 if i was you .. 40 series is gunna be to tall imo . ive been researching alot of set ups ..and a 30 is way to low unless you run a 305/30 or higher atleast for the rear . im all most positive a 275/35 on a 10 inch rim will fit on the front since there gt350 rims im sure there offset is made to fit unlike other rims that need a spacer
Jon|3.7
Houston, Tx
15' 3.7 Mustang
my current set up is 20x10 et35 275/35/20 (im lowered on progressives) ive also seen 20x10 et40 with the same 275/35 tires
jbailer
Joe
Wouldn't 285/35 be better?
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
You could do a 285/35/20 as well but there are less options and their more expensive.
Unless you do the BFG G force Comp 2 A/S those are awesome and super affordable.
16_DIB
Fairfax, VA
Hector
2016 GT Premium PP
I would definitely do 305 or 315 in the rear! 275 is good for the front.
wildcatgoal
@sirboom_photography
TBD
You have a PP so mount the rear wheels up front. You may need to grab a 5mm spacer from Autozone or something to make it go on there, but just mount it safely and drop the car down for a look. You'll then have what a 275/40 looks like. It won't look bad.
275/35 gets you a lot more tire options and I've seen it with your exact wheels, looks great.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
You could but these are the SVE 20" so their 10" wide at most.
He got the 20s brotha not the 19s
