So you were able to run the 3.5 with straight 93 no octane booster?Better believe there are some 9sec pump gas S550s out there.
Not the 3.5. I mean maybe I could but my tuner says don't do it. I need Octaniun on that. But it's definitely possible to run a 9 on the 3.6 with 93. I ran on pump just out of curiosity and went 10.0x. only did a couple passes and then switched setups. Haven't run again on 93 but I'm sure it would do it after all the time I've spent with the car now. If I've been 10.0 on a hot day I'm sure some folks out there have been 9s. Next track rental I'll probably try it just to get the number.So you were able to run the 3.5 with straight 93 no octane booster?
Do you know what your car weighs?Not the 3.5. I mean maybe I could but my tuner says don't do it. I need Octaniun on that. But it's definitely possible to run a 9 on the 3.6 with 93. I ran on pump just out of curiosity and went 10.0x. only did a couple passes and then switched setups. Haven't run again on 93 but I'm sure it would do it after all the time I've spent with the car now. If I've been 10.0 on a hot day I'm sure some folks out there have been 9s. Next track rental I'll probably try it just to get the number.
4120 last time I put it on the scales with me in it.Do you know what your car weighs?
