Fan problem. Fans come on and stay on when I start the engine. Even with AC off. [Solved?]
16RRGT
Roush Phase 1
SW Washington
16 GT; 85, 69 Camaro, 2000 F350 Dsl Dually
Pretty much self explanatory. A couple seconds after the engine starts, the fans come on and stay on until the engines turned off. Even when the engine is cold.
2016 5.0 Roush 2.3 dealer installed, Roush tune, no changes in tune or any other modification.
What should I be checking?
UPDATE: Weeelllll.... it stopped. On it's own. I have no idea why it started and no idea why it stopped.
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
Oh shit!!
J/K probably just a stuck switch. Any codes?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Is your A/C on?
16RRGT
16RRGT
Roush Phase 1
SW Washington
Oh shit!!
Nothing. Other than being an annoyance, there's no problem except it's likely to increase the time the engine needs to warm up.
Arknsawchuck
Cabot, Arkansas
Chuck
2019 Mustang GT PP2
If I got this right the fans should kick on when the engine has hit a preset temp. So it seems something is telling the fans the engine has hit that temp. Thats my best armchair guess. Id start looking for a sensor or switch in that system.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
bauern
somewhere else
Robert
F150 Powerboost
Connect a scan tool/code reader to it and see what temp the sensors are telling the PCM.
16RRGT
16RRGT
Roush Phase 1
SW Washington
I did that today. Nothing shows.
16RRGT
16RRGT
Roush Phase 1
SW Washington
OK. No codes. So. I'm going to start with the coolant temp sensor.
If I can find it. So far, no joy. Any ideas?
K4fxd
NKY
Good luck finding a coolant sensor........
There is none, the PCM infers if from the cylinder head sensor. It will usually run 10 degrees cooler then the CHT dash display.
You need a live scanner.
Super-Genius
Austin Tx
Timothy
2020 Oxford White Mustang GT
This probably won't help, but I had my GMC truck do the exact same thing. The vehicle wasn't getting hot either. Turns out it was the thermostat. I thought that was really weird, but hey, it's fixed, and hasn't done it again.
