Cruizer
- Mar 16, 2021
- Western Ohio
- David
- 2020 Mustang Ecoboost Premium
- Vehicle Showcase
- 1
Lately at low idle to slow acceleration I've been hearing some clanking or chatter. I could tell it was metal and sounded like exhaust. So I banged around on the exhaust tips and sure enough, clank, clank, clank. I look up under there and the hangers right before the exhaust splits in different directions are rubbing the rear sway bar. The sway bar even has some wear on it.
The rear end has BRM Performance 0.5" lowering springs. I'm also running a Roush Catback Exhaust. I crawled under it today and busted everything lose. I could not get the exhaust to move up and away from the sway bar. I lowered the car and reset it on the ground. Look up under it and still on the sway bar. Lifted the car 1/2 inch, still on the sway bar.
Only thing I can think of is cutting a 1/2 - 3/4 inch of the pipe connected to the downpipe. There is not a lot of rear hanger to pull away from though.
Has anyone run in to this problem? Could you fix the issue?
