Exclusive: Shelby Performance LED Fog Light / Marker Light Kit GT350/GT350R 2015-2018
Status
Not open for further replies.
higdominator
Central Oklahoma
2016 GT PPP
Cavdiddy
Lake Elmo MN
Drew
2017 gt350. 87 T-top Fox . 2019 Raptor
I just tried looking on CJPony for this kit - appears they no longer carry it? or perhaps I just couldn't locate it.
mrbillwot
Greater Boston Area
Bill
'19 Kona Blue w/blk roof & blk stripes GT350, 89 LX5.0 Sedan (Mustangs Past: 69's Coupe, Mach 1, & GT)
Same...so bummed and I presume the problem is Shelby doesn't have the bespoke lamp portion of this kit. Ridiculous these cars have no fogs and now there seems to be no mod option.
Tb8983
F.G. Oregon
2018 GT350
Shelby Performance Parts LED Fog Light and Marker Light Kit for all 2015, 2016, 2017 and 2018 Shelby GT350 and GT350R Mustangs.
The 2015-2018 Shelby GT350 and GT350R is all business, so it’s easy to understand why Ford would leave out something as simple as Fog Lights when designing what is arguably the best looking and most functional front-end to ever grace a Mustang. But today you can change that without taking away anything from the styling or aerodynamics found on your beloved Shelby.
We have worked closely with Shelby Performance Parts and Starkey Products to bring you a truly bolt-on, plug-and-play upgrade that requires no permanent modifications and will easily provide any Shelby GT350 or GT350R owner with fog light capabilities that were otherwise left out during the design and engineering process. Now is the time to order this complete LED Fog Light and Marker Light Kit from Shelby Performance Parts and Starkey Products for your 2015-2018 Shelby GT350 or GT350R Mustang, found exclusively here at CJ Pony Parts!
Kit Includes:
- (2) LED Fog Light/Marker Light Assemblies
- OEM Ford Headlight Switch with Fog Light Button
- High-Quality Wiring Harness with Relays and Fuses
Features and Benefits:
- Direct Replacements for the Factory Marker Light Housings
- DOT/SAE Compliant Fog Lamp, Turn Signal and Sidemarker Functions
- Inner Side LED Optic Produces a Wide, Bright Fog Light Pattern
- Outer Side Reflectors Illuminate Amber for Turn Signal and Sidemarker
- Chrome Inner Bezel Provides Factory-Grade Appearance
- OEM Ford Headlight/Fog Light Switch Included for a Seamless Factory Look and Feel
- Direct Connection to Factory Electrical Harnesses with No Permanent Modifications
- Easily Provides Fog Light Capabilities to any Shelby GT350 or GT350R
Fitment:
- 2015-2018 Shelby GT350
- 2015-2018 Shelby GT350R
*This kit is NOT compatible with any other models that did not originally come equipped with factory fog lights.
Please Note: This is Shelby Performance Parts LED Fog Light and Marker Light Kit is NOT compatible with the Diode Dynamics LED Switchback Turn Signal Bulb and Cool White Side Marker Kit.
*There will NOT be an indicator light showing fog light status inside the vehicle.
Tech Tip: The system is designed to automatically turn OFF when the car is turned OFF. In addition, the fog lights will remain ON when you activate the high beams.
Order this Shelby Performance Parts LED Fog Light and Marker Light Kit for your 2015, 2016, 2017 or 2018 Shelby GT350 or GT350R Mustang from CJ Pony Parts today!
@CJ Pony Parts we need this kit available agian. Make it happen
Decible
Georgia
Sam
2023 Mach 1 HP
I wonder if something like this could be used on a Mach 1 bumper conversion on a GT that has fogs and the switch already?
mrbillwot
Greater Boston Area
Bill
I'm guessing that CJ isn't the problem - its that Shelby isn't making the lamps. CJ just kitted & sold the components from various suppliers. Unless Shelby start making them again we're SOL.
Decible
Georgia
Sam
2023 Mach 1 HP
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
Decible
Georgia
Sam
2023 Mach 1 HP
Unfortunately, we only offer our Sequential LED Turn Signals for 2015-2017 Ford Mustang (pair) (USDM).
Could you all reproduce something like this?
Diode Dynamics
St. Louis, MO
Unfortunately, R&D would take an extensive amount of time. We only will be offering our 2015-2017 Ford Mustang Sequential LED Turn Signals at this time. Sorry about that!
Decible
Georgia
Sam
2023 Mach 1 HP
I would be in for this as well…
i just missed the last kit at CJs 😝
Me too, this would be perfect for anyone that wanted to do a Mach 1 conversation and keep the fogs 🥴 there is a need for this and I need it 😂
@Diode Dynamics If we could get a group buy on these would the juice be worth the squeeze for anyone wanting to do a bumper conversion to a Mach 1 or a 350 bumper on a 15-17 could use these as well.
Tb8983
F.G. Oregon
2018 GT350
I emailed starkey the company of the wiring harness and this was there reply
Decible
Georgia
Sam
2023 Mach 1 HP
@Diode Dynamics John if we could get a group buy together how many of us would we need to round up to get this off the ground? I also wonder if someone on the forum has a set of the old Shelby part if you could scan it and maybe help you out and cut the R&D time down?
Status
