Ace
- Sep 28, 2014
- Germany
- Website
- www.modernmusclecars.de
- Steve
- 2018 Camaro 2SS (EU)
Here's a quick comparison of the gear ratios between current MT82 3.55 and the Tremec with 3.73. The difference is huge, this alone will the big game changer in the manual Mach 1.
Current gear ratios just suck, especially with europes 3.55 downgrade. 3 and 4 are way too long to put down power and having two overdrive gears are just useless here since the car is limited to 250 km/h which you already pass in 4th gear.
This is how the gerar ratios in the Mach 1 should look like. It can finally use the power of the Coyote (which really needs the RPM) and uses the 5 gears to have the maximum power at every speed and then just have the one long overdrive for better mpg on highways.
