I still have my racestars front and rearsI want these so bad, but I'm not ready to get front runners yet. :(
I wish brotha. Fronts wont fit my car, and I want tires I can run on the street out back. But I do want them :(I still have my racestars front and rears
thanks for the update:cheers:At the track... 3500 rpm clutch side step at 19lbs of air pressure will dead hook!!!!
Nice and stable with radial pizza cutters on the front. I will update later with time once I grow a pair and launch higher.
I drove to the track with them on. Mix of back roads and highway. With 25psi in them they were surprisingly stable. No pucker moments.GTBOB do you drive to the track with them on already or do you swap at the track/trailer there?
Thanks for the update, good to know they work fine with the front M/T Sportsman skinnies. Did you come from a rear drag radial ? I have the M/T ET Street Rs and hate that there finicky, hope these are more forgiving.I drove to the track with them on. Mix of back roads and highway. With 25psi in them they were surprisingly stable. No pucker moments.
For me at the track, 4K rpm clutch dump with 18psi in them prevented bogs. Any rpm less than that it would dead hook and fall on it's face. I'm running half a second and 4mph slower than last year though. Only difference is all my GT350 induction and complete stock exhaust now. Frustrated but I'll get it figured out.
Hmmmm...wonder whats getting you? I know that Bias Ply's can suck some MPH off but shouldnt hurt the ET that bad! Hope you sort out whats holding you back and thanks for the info, I might be picking up a set here soon!I drove to the track with them on. Mix of back roads and highway. With 25psi in them they were surprisingly stable. No pucker moments.
There's a couple different options in 26 tall tire but on a 17 inch wheel it's hard to get sidewall. ET Street R make a 275/40R17 that I run on motor and it hooks fine and have no complaints. M&H makes a 275/50R17 which has more sidewall it's closer to a 26.5-27 tall tire. Kinda in between the two.Interesting. With a 26" tire would you have enough sidewall to get the benefit of even going with a Bias tire? Im on stock 3.73s so I feel like the 28" will work just fine but only one way to find out!
