Estimate the 2019 GT500’s HP. *Poll*
What will be the 2019 GT500’s HP range?
  • Total voters
    245
  • Poll closed .
Tomster
Beware of idiots
Tom
^^^ we'll see about that one. And then came along a guy named Hackett
cweller
California
Mustang
If that ratio was true and accurate I was thinking the same thing. 725 hp would be around 4160 pounds. If it were to weight about 3900 lbs it would be roughly 675 hp, would that be preferable?
This can't be right. We need to wait for announcement from Ford. But anything over 3,900lbs and/or less than 700hp is going to be a disappointment. In my opinion, the car needs to have at least 50-75hp more than the prior GT500 and be under 3,900lbs for it to out-perform the competition.
ttime500
seattle, wa
2016 Corvette Z06
I’m not saying it’s the truth! Someone with “inside” knowledge said power to weight ratio is 5.76 which if 725 hp that makes weight around 4160.
SpursFan
Over yonder
2016 GT350
No way it ways over 3850. If it does Ford should go back to the drawing board regardless of HP. My in out decision will be more based on weight than HP. A few extra HP on a supercharged engine is a simple bolt on fix shedding 200 plus pounds is different story.
ttime500
seattle, wa
2016 Corvette Z06
I would say unfortunately I doubt that happens. I’m hopeful they keep it under 4000.
02gtnh
Nh
16 corvette conv. 17 F150
The GT350 almost weighs that, so I can’t see all the extra need to go into the GT500 to add only 50-60lbs more. A fully loaded Mustang GT is heavier then 3850lbs.:cheers:
65Terdlingua
Kansas City
1965 Mustang
Bigger brakes, a LOT more cooling, a supercharger and ancillary components. What makes you think it will be under 3850?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
They are adding lightness. Not confirming <= that number but they're not just taking a GT and adding a ton of stuff with no substantial weight reduction.
ttime500
seattle, wa
2016 Corvette Z06
That’s good to hear. Someone posted a power to weight ratio of 5.76 accurate or crap?
SpursFan
Over yonder
2016 GT350
The Ford Performance guys seems to have their heads on straight and if you look at what fords done in Motorsports... I lean (hope and pray!) to belive they understand the point where more HP doesn't make the horse faster. I certainly see where the added weight will come from but I expect some of that to be offset by other measures.
NightmareMoon
2016 Mustang GT PP
Maybe they'll go the Doge Demon route to save weight and remove BOTH front seats
SVTSNAKE351
chicago
2014 GT500
:cheers::ford::lol:There is no reason for the next GT500 not to have over 850hp!!
