ESS Centrifugal Mustang Superchargers
jjw
upper midwest
www.shelbyparts.com
'19 PP2, 05 STI 475whp, 04 cayenne turbo, Shelbys
Apparently we need to buy 2k worth of fuel system to be tuned by LUND cause some tard wants to pulley down. There are much better places to get a tune IMO.
Yes, this doesn't affect me at all. I have a Mustang dyno next door I can use whenever I want, a good local tuner, and several tuners I have worked well with remotely. The last thing I'm worried about is a tune. I'll probably put it on the dyno and have my local guy come over.
mazikeen
indianapolis
chris
2015 mustang gt
any recommendations for installation around Indianapolis area? Work a crazy amount and time at home is mostly with new baby and wife. I have a feeling ill never get to doing the install on my own...
olaosunt
Indiana
Don’t have his card but Justin’s performance is who i would recommend .
317-430-3035
Tell him you were referred by Olaniyi .
kevinvan6000
Ontario
2020Mustang GT
anyone able to take a look at the attached logs? Both .csv and .hpl files are attached. STFT's seem off, it looks like its pulling fuel. Not my car, just trying to help someone out but I don't know enough about logs to pinpoint what is going on. Thanks
Jonyxz
San Juan, PR
2019 5.0 401A 10R80
For those with an a10 and tuned by Lund, how good was your transmission tuned? Do you still retain drive modes with their characteristics?
TEXAS HEAT
TEXAS
2019 Mustang GT PP1 A10
The Lund A10 transmission tuning on my car shifts very firmly even at part throttle, but it shifts absolutely on point under WOT conditions. I will likely ask for a little part throttle massaging to combat the part throttle firmness because it causes the car to buck and surge after a shift is excecated. All drive modes work as it did before, but shifts are definitely firmer in any mode selected, most likely a result of the increased trans pressures to prevent slip.
TEXAS HEAT
TEXAS
What fuel is your friend on and what mods are on the car? The STFT's are trimming 13-15% less fuel to keep AFR's at .75 lambda.
kevinvan6000
Ontario
2020Mustang GT
It's from @luis5.0 car. I'm not 100% sure what the fuel is. Hopefully he can answer. He asked me to take a look to try and help him out.
luis5.0
Virginia
Luis
2020 Ford Mustang GT
93 shell fuel. This is on a PBD base map. So far I’ve sent idle, drive, 2500-7000 WOT logs to PBD. Waiting on a revision which I should get on Monday since WOT log was sent Friday 4pm.
TEXAS HEAT
TEXAS
Your afr's seem fine, but air load seems low to me, what pulley are you on? Are you sure you don't have a boost leak?
The stft's are taking 15% less fuel to keep your afr's at .75 lambda. This much correction is a little on the high side imo, but all of your other fueling parameters seem good to me. Assuming that I am interpreting things correctly.
luis5.0
Virginia
Luis
Im on a 115mm pulley so 8.5psi for now. I’ve double checked every clamp. The BOV sounds like it’s doing the right thing but what should I look for to check if the BOV is leaking?
TEXAS HEAT
TEXAS
You can try revving the engine and listening to see if air is escaping when the BOV is supposed to be closed, but before I would take the front bumper off again to troubleshoot this, I would just wait until tomorrow for PBD to give you their input.
I'm on the same pulley and I'm seeing 1.5 air load at that RPM and yours is under 1.2
Bigg 5.0
Virginia
Kyle
2019 mustang gt
Has any one tried running any catch cans with their Ess kit?
16 - CJ Pony Parts - 2
