- Feb 7, 2022
- Chandler, AZ
- 17 Mustang GT
If your car is a gen 2 it should have two lines that went to the factory air inlet and the other line will go to the T fitting. I have seen a few Gen 2 cars have only 1 line going to the factory air inlet. If that is the case I can send you the straight fitting with one connector to replace the T. For now just cap off the one end that isn’t used and run the BOV line to the middle port.Trimming about an inch seemed to do the trick, now it's just a slight contact.
One other question about vacuum routing: I got the drivers side pcv hooked to the inlet tube, and the one connector into the T where the BOV goes, but I'm not sure what goes into the other side:
(I tried to call ess support, but they aren't open yet)
