Brad1810r80
- Jul 22, 2021
- Huntsville AL
- Brad
- 2018 Mustang 2018 F150
No issues here at all even on e85. What fuel are you on?
Are you running 93 or E85? I notice it more often on E85, my mechanic said it is because it is semi vaporizing in the rails sitting in them after shutdown just cooking in them. Mine will stutter for a few seconds but ends up idling normal with 15-20 seconds usually if it has been hot and parked for a bit on restart.Does anyone living in any of the hotter areas (100F+ ambient temps) have any issues with hot starts?
If temps are hot outside (100F+) and I turn the car off for about 30 minutes or so and come back the car sometimes struggles to start on the first crank (even stalls on occasion). Starts on the second try though.
Doesn't happen in the cooler months.
Was wondering if anyone has experienced the same thing
Practically the same as what's described in this thread (and a few others):
https://www.mustang6g.com/forums/threads/hot-start-issue-18-gt-w-procharger.125681/
Happening on different tunes I have so not specific to a single tuner
Same as yours, ID1050XI live in Phoenix and don't have any issues with hot starts. What injectors do you have?
I'm on E85No issues here at all even on e85. What fuel are you on?
That's exactly it but mine also ends up stalling once in a while.Are you running 93 or E85? I notice it more often on E85, my mechanic said it is because it is semi vaporizing in the rails sitting in them after shutdown just cooking in them. Mine will stutter for a few seconds but ends up idling normal with 15-20 seconds usually if it has been hot and parked for a bit on restart.
Are you running meth injection?Does anyone living in any of the hotter areas (100F+ ambient temps) have any issues with hot starts?
That's really interesting. Do you have any theories on why the meth would be causing the issue?Are you running meth injection?
I just started having this issue as it has consistentky been around 100* in Utah and narrowed it down to my meth injection (after checking a long list of things). I added a solenoid just before the nozzle and that helped a little but it will still stumble and many times stall on a warm start if it has been sitting for more than about 15 minutes. Before I moved the solenoid closer it would stall almost every warm start, now it's about 40% of the time.
Still trying to get it more or less resolved, but the meth system is the cause for me. (Started a whole thread on it)
My current thought is that I am spraying too much and it is pooling up in the intake/elbow/intercooler. And when it sits for about 15-20 minutes when hot, it is gassing off or something causing an overly rich condition on first start. Second try, fires right up after it is cleared out. I don’t have a way to be sure this is what is happening, but at this point it is all I can think of.That's really interesting. Do you have any theories on why the meth would be causing the issue?
Will search for your thread
That's a very interesting theory. I'm on E85 so I'll turn off my meth completely for a few days and see what happens.My current thought is that I am spraying too much and it is pooling up in the intake/elbow/intercooler. And when it sits for about 15-20 minutes when hot, it is gassing off or something causing an overly rich condition on first start. Second try, fires right up after it is cleared out. I don’t have a way to be sure this is what is happening, but at this point it is all I can think of.
I thought it may be a siphoning issue but with testing solenoids and check valves the problem still occurs.
I completely removed the nozzles and deactivated the system for a few days and the problem immediately went away. Hooked it back up = hot start issues.
Every 5k after break in.Does anyone remember the recommended mileage to change the oil in the blower? I want to say 2500 miles but I can’t remember…
The break-in mileage was what I was looking for, thanks!Every 5k after break in.
Starter is going out. Will continue to get worse until it won't crank at all. Classic diagnosis symptom. Will crank when cold (not expanded and binding) but not when ran/hot.I live in Phoenix and don't have any issues with hot starts. What injectors do you have?
Curious since I’m battling hot start issues myself.Starter is going out. Will continue to get worse until it won't crank at all. Classic diagnosis symptom. Will crank when cold (not expanded and binding) but not when ran/hot.
Yeah, that's not starter, that's something in tune/air/spark/fuel.Curious since I’m battling hot start issues myself.
In my case, the car cranks and fires almost immediately gets up up to 900ish rpm’s then chokes out. I can also start it in flood clear mode (brake and gas pedal held at the same time) and it will crank just fine.
I’m assuming that would rule out the starter being the culprit? (Aside from the fact that disconnecting my meth injection also cures my starting issue)
