ESS Centrifugal Mustang Superchargers
TEXAS HEAT
TEXAS
2019 Mustang GT PP1 A10
Really impressed with this fuel system so far. Hardly needed any tuning. The boost reference line adds fuel predictably. For about 500 more than a dw and bap it's well worthit. I should have done this from the start but did not want to have to run my own lines. With this kit I'm using the stock fuel line, aftermarket rails and no return line since the regulator is in the hat. You can run your own lines if you want. These snips are a before and after. See how on the bap and dw the pressure drop is immediate then the bap kicks in and it starts squeezing a little more out of the pump until the pump cant keep up and bottoms out around 35psi. Also notice the EQ ratios can't maintain the commanded ratio so they begin leaning out before the pull is over. The 100mm pulley is consistenly making around 14 psi at 7300-7400. On all my logs its like the MAF lags behind when its really making steam. Before my foot is off the gas and the boost has reached its peak the MAF tops out. I'm not sure if I need a new MAF or its just not keeping up with the airflow. I highly suggest anyone making over 750ish get a dual pump system.
What did you end up setting your base fuel pressure at?
kenand1988
Phoenix, AZ
2020 Mustang GT
WIST2019GT
Madison
2021 Mustang GT
I was looking for some larger injectors and I got some. I wanted to replicate Shawn's 994 number on the 100mm. I switched to e85 larger injectors larger rails larger feed line. No fuel restrictions possible. The car made 893 which is about 15 more than on the previous setup with smaller injectors, stock rails, lu47s, dw400 and bap. I personally think lu47s could do e85 and make over 950 wheel with the proper boost. Long story short though. I don't see the benefit in upgrading anything other than the fuel pump unless you are reaching for 4 digits.
I have a G3X on the 110 pulley (fuel system, e85, etc) and based on weight and what it trapped I think it makes 775ish at the tire. You made ~115whp more than me going down to the 100mm although on the standard compressor wheel (not sure if that's even a measurable difference). Do you have any exhaust work? I think my car having a completely stock exhaust is hindering some power considering I was only seeing 27ish on the back half at the track.
Jessemw003
Jesse
2015 Mustang Gt 50th Anniversary
Stock exhaust will definitely put you down some power. Put some headers and a better cat back and you’ll get the power up there
WIST2019GT
Madison
2021 Mustang GT
I have a set of header with off road leads and a tubular kmember going in shortly. I was hoping someone would have real world data showing the gains. Yolo had a video where he gained 50whp on a 2019 vortech car that went from stock exhaust to catless headers and the factory catback.
Id be happy with 35whp.
TEXAS HEAT
TEXAS
Actually, he gained 20whp with the addition of the 3' MAGNAFLOW exhaust. He was already equipped with long tubes and an FFE. You will likely add an additional 50whp by eliminating the factory exhaust manifolds, cats and stock cat-back on a boosted application.
WIST2019GT
Madison
2021 Mustang GT
I know he also did a video on the cat back.
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
Having everything the same, will the g3 make more power than the g2? Same pulley size, same injectors, fuel, everything
pittzy23
Wisconsin
Corey
2020 Mustang GT
Yes; probably around the 40-50 whp mark with all else equal
kenand1988
Phoenix, AZ
2020 Mustang GT
catless stock exhaust manifolds, x pipe and stock active valve exhaust. From what i've been told the G3X doesnt shine until you start to overspin the G3. So I would think the results between the two would be basically the same. I say that but as we all saw Shawn's car made crazy power on the G3X, something like 1104 on the 95mm and 994 on the 100mm. Aside from the x trim and his being an auto our cars are really similar. He I think is in Indiana and I'm in AZ so sure I wont make quite as much as him and thats if the dynos are reading close to one another but I think it could just be tune related. Lund has figured out the right method of getting the most out of these setups. I did have my car dyno'd again this past thursday with the new fuel system and it did 893/650 on the same dyno I have always gone to.
Mustang8111
Cnd
2021 Mustang gt
Well car fired right up with base tune. Thanks wengerd Perf!
Problem is I have a coolant leak at new black 90 degree ess piece. Bolts are tight. Am o missing a gasket or oring?
Anyone else have this issue?
Colin1337
WA
2019 Mustang GT PP1, 2015 VW GTI PP
i believe there is an o ring in there. I replaced mine since I was also doing the 170* thermostat. You may have pinched yours somehow
Mustang8111
Cnd
2021 Mustang gt
Well that’s not good
I definitely don’t have a o ring
Where does this o ring go?
When changing the ess piece , the thermostat almost fell out.
Any Pics by chance
Looks like I’m taking shit apart.
Jessemw003
Jesse
Any Pics by chance
The o-ring should be the same size as the oem one. Just reuse it
Mustang8111
Cnd
2021 Mustang gt
There was no oring in the kit. But found this down under The alternator. I’m guessing this is the missing O-ring
63 - Late Model Restoration - 1
